Notices
unique shift knob
Old 12-12-2005, 03:37 PM
UFGatorG35's Avatar
What are you guys having trouble with that caused you to scratch up the shift ****? I was able to remove the old **** and tighten the new one by hand, would yours not turn? Sucks to hear they got marked up...
  #107
Old 12-12-2005, 04:49 PM
Fini's Avatar
My arm would've twisted off first before the **** would even move.
  #108
Old 12-12-2005, 06:54 PM
keefyt's Avatar
I had the same problem this weekend Partly my own fault, the tools I used had large teeth, so they went through the rags I was using. Although it would have been nice to be able to twist it off by hand. It needed at least 3 full turns with the tools before it was loose enough to turn by hand.
New one is awesome, much better feel, smoother shifting, seems easier to locate gears. Great job Clint !!
Later.
  #109
Old 12-12-2005, 08:06 PM
Andy2434's Avatar
LOL . . . Okay, I don't fell so bad, now. I dinged up my OEM **** while removing it, as well. I use a large pair of adjustable pliers with a towel wrapped around the ****. Yet, I still managed to scuff up my OEM ****.
Upon removing the OEM ****, I noticed a fair amount of a dried blue liquid lock tight substance. I had to have someone hold onto the vise grips, which were gripped onto the shifter shaft, as I tried to turn the OEM ****. It took many turns before I could remove the **** by hand, as well.
The bright side of all this is that . . . The THX-SS **** looks GREAT!
  #110
Old 12-12-2005, 08:19 PM
GEE PASTA's Avatar
Florida G35 Club
Andy
Can somebody post a picture of this ****.
I don't have the time to read this whole thread.
I need to be out in the garage installing some innovating Motordyne Engineering Item's.
You know you will get that PM from me when the time is right. Pasta
  #111
Old 12-12-2005, 08:21 PM
Fini's Avatar
I've posted some pictures a few post up... just scroll up and you'll see it!
  #112
Old 12-12-2005, 08:58 PM
Andy2434's Avatar
Pasta,
Yes, see David's (Fini) post #98. He did a great job with pics. It's a wonderfully designed and built shift ****. Clint did a great job with shift ****. The pics do the shift **** no real justice.
  #113
Old 12-12-2005, 09:37 PM
GEE PASTA's Avatar
Florida G35 Club
Pasta,
Wow!
looks great. thanks. Clint good job.
  #114
Old 12-12-2005, 10:14 PM
THX723's Avatar
G Kreuzer
Thanks Pasta and the others!
Those hoping to catch one last opportunity for these ***** should check w. Sharif at My350Z.com, here: http://www.my350z.com/forum/showthread.php?t=158133
I'm shocked to read of all these brutalities trying to take the oem **** off. Eeesh!!!
It really shouldn't be that trammatic at all. Soaplag just came by the other day and I was able to pull his oem **** and install the THX-SS **** all in less than 3 minutes using only my two bare hands and a vice grip that he was holding. That was the very first '05 I've performed the procedure on ... and it was absolutely no different than the '03/'04s I've worked with. Yes, it is extremely tight, but it does come off. heh heh!
  #115
Old 12-12-2005, 10:33 PM
GEE PASTA's Avatar
Florida G35 Club
Clint
Is I true that you get that extra strength by doing 12 oz curls after popping the top of your favorite beverage?
  #116
Old 12-12-2005, 11:53 PM
THX723's Avatar
G Kreuzer
Especially ones that are tagged "New Castle"
  #117
Old 12-13-2005, 04:19 PM
soaplag's Avatar
Great Shift ****
Thanks for the help in installing the ****...didn't have a vise gip so it would have probably taken me a long time...I'm diggin the ****...like the weight, feel...had a chance to check out an aluminium Razo **** the other day, and it was too light for my taste...had some people try out my car and they liked the feel...thanks again for the help...maybe i'll see you at one of those meets in chino.
  #118
Old 12-13-2005, 07:17 PM
RBull's Avatar
Rated M
Thanks fro the heads up Clint,
I got mine ordered. How does the shifter console cover come off? Just pull up?
  #119
Old 12-13-2005, 07:47 PM
Andy2434's Avatar
Yes, Deane . . . Simply grab the rear of the console below the shifter boot and pull. Pop! It comes right out. The ash tray and e-light switch is all connected to this assembly.
Hint: Leave your shifter in "Neutral" for an easier install, if it is possible.
  #120
Old 12-13-2005, 09:21 PM
RBull's Avatar
Rated M
Thanks Andy. This shifter looks like a great piece. Does it make a difference with the throws since it is smaller than the original?
Quick Reply: unique shift knob
