Just installed 06 hlps, Taillights, fogs,city lights NOT WORKING
Old May 31, 2006 | 09:51 AM
wreckeds2k's Avatar
Just installed 06 hlps; Taillights,fog,city lights NOT WORKING
Just installed my 06 projectors and the sunroof, fog lights,tail lights and city lights not working...Any help out there..Checked all my fuses and two of them have no power on either side..It is the two 10amp fuses on the forward side if the fuse puller...My car is an 05...Thanks Derick OH YEA THE PROJECTORS AND SIGNALS WORK..BUT the signals in the bumper dont!
Old May 31, 2006 | 12:06 PM
IvoryGT's Avatar
those are spares. the fuses you need to check are under the hood next to the battery, The box is sitting against the firewall and to the left of the battery.
Old May 31, 2006 | 12:30 PM
wreckeds2k's Avatar
Yea, I know, I checked all of them.... Next quest is to check the grounds.
Old Jun 1, 2006 | 09:42 AM
Steel Blue's Avatar
Did you get this working?
Old Jun 1, 2006 | 01:16 PM
IvoryGT's Avatar
it is the VERY top one in the engine compartment fuse box
Old Jun 1, 2006 | 02:40 PM
wreckeds2k's Avatar
As much as I work on these
As much as I work on these you think I would have remembered that.!!!!
I pulled the cowl screen off and boom! there it was..3 blown fuses..My sunroof still doesnt cooperate. Hit the button and there is nothing there. At first it would just go back but I wound it forward and then it just goes up/down..You have to keep hitting the switch. Now its stuck up. Thanks Ivory GT and everybody else..
Old Jun 1, 2006 | 03:00 PM
IvoryGT's Avatar
I can't imagine the 06 did this to your car, all the circuit and load should be the same. There could be a short somewhere that's causing this. I experience the same problem only because I installed the Quad projectors and 2 extra ballasts draws extra current initally and so I changed the 10A to 15A and everything is fine now.
Old Jun 1, 2006 | 04:19 PM
wreckeds2k's Avatar
Which fuse did you upgrade?
Old Jun 1, 2006 | 05:19 PM
Steel Blue's Avatar
It doesn't make sense to me why a fuse would blow since you are still using the the same D2 xenon bulb. The only thing that has changed is the headlight housing.
My car was in an accident and the body shop is installing the 06 headlights for me as well. If they get done anytime soon I will let you know if they did anything different.
Keep us updated as well.
Old Jun 1, 2006 | 05:32 PM
IvoryGT's Avatar
I might have to get back to you on that I need to look at my manual to be exact.
Old Jun 1, 2006 | 07:09 PM
wreckeds2k's Avatar
Thanks Ivory GT, and my car was wrecked also "wreckeds2k"
Old Jun 5, 2006 | 10:49 AM
Steel Blue's Avatar
Any updates? Everything working now?
Old Jun 5, 2006 | 02:14 PM
wreckeds2k's Avatar
everything is working now..My car was in a wreck and the complete pass. side wiring harness was cut in half..I soldered and heatshrinked everything back to normal. I had blown fuses that were under the cowl screen fuse box. The sunroof still didnt work but I turned switch off/then on, hit button up 6times turn switch off/then on, hit up 6x; same procedure 3 times.. Then hit down button switch off/then on and everything works fine.
Sounds like big process.. But not too bad. Thanks again for the help and questions. Derick
Old Jul 10, 2006 | 10:08 AM
LEXREX's Avatar
You selling the other headlights???
Jusseth
Sep 13, 2020 12:25 PM
realtalk21
Jul 20, 2015 09:07 AM
attarday
Jul 15, 2015 04:03 PM
