V-leds installed *doors, plate, and reverse*
Old Sep 15, 2006 | 12:11 AM
dream_G35's Avatar
Ok here is the pics i promised those looking at V-led lights.
Here is the list of the exact bulbs i bought.
License Plate (168): 2 HID White Inverted Cone Wedge Base LED
Back-up(reverse) light (921): 2 Super HID White 9 LED
Step light (under door panel)(3175): Super HID White High Power LED Bulb
All bought at V-leds.com
My thoughts: I was looking for nice WHITE lights when i got these (since my car is IP). Well that wasn't the case, i guess they are too high power reflected or whatever to be white so they turned out blue to me...
p.s: dont get me wrong these are very bright and nice lights but not the "white" i was going for. PLEASE GIVE ME YOUR OPINION and Let me kno if they look ok even though they are not pure white, thanks. (im asking for opinion cuz im very picky)
*PICS*:
Interior: Drivers door open
Interior: Passenger Door closed
Old Sep 15, 2006 | 12:34 AM
anDross's Avatar
welcome to the club.. looks nice
Old Sep 15, 2006 | 12:39 AM
dream_G35's Avatar
i guess the only thing that made me not smile so much is the fact that my fogs are a hyper yellow so these lights throw everything way off. should i change the fog bulb to something close to this color or change the v-led lights to some type of amber. I confooosed
Old Sep 15, 2006 | 12:44 AM
anDross's Avatar
leave it as is.. it'll grow on you. I have yellow fogs too and everything seems to match when you look and smile for a while
Old Sep 15, 2006 | 12:50 AM
Hitman_'s Avatar
great for lakeshore cars. Where you buy?
Old Sep 15, 2006 | 12:57 AM
Calvin's Avatar
Overglorified Altima
uhhm vleds.com
sweet! welcome to the led reverse light club! LOL
i LOVE how mine looks..i get compliments all the time for them, no joke!
Old Sep 15, 2006 | 11:49 AM
richboy's Avatar
MORE POWER PLZ!!!
Hey Dream g35. Can u show me how to remove the rear taillight? I tried removing it last time but it was werid i couldnt find the spot for the reverse light...I found the brake like connector but cant find the reverse one.
Old Sep 15, 2006 | 05:52 PM
Bigd2k6's Avatar
remove the plastic cover on the trunk latch (the car latch not the hood latch). pry back the carpet and remove the (three?) nuts from the long bolts using a deep well socket. the bolts are molded into the light housings. after the nuts are removed, slide the tail lamp assy straight back. do not try to remove on corner faster than the other because the bolts will bind up on the holes. remove the reverse light socket by turning it and assemble in reverse order. takes like 20 minutes to do both as long as you don't drop any nuts (like me). and don't tighten them too hard or they'll snap the bolts right out of the housing. hope that helps.
Old Sep 15, 2006 | 06:02 PM
dream_G35's Avatar
yup wut he said^^ they are 3 bolts size 8mm i believe small ones and they aren't on tight at all. Just try to use something magentized because those little bolts will want to fall right out of your hands if your not careful and it will VERY time consuming and hard to find if it falls.
Old Sep 15, 2006 | 09:05 PM
anDross's Avatar
yep.. I installed my 06' jdm tails and it's the same thing for removal of the tailights and the bulbs all together
Old Sep 16, 2006 | 04:15 PM
richboy's Avatar
MORE POWER PLZ!!!
Thanks guys..I tried doin that last time couldnt find it..ill try again later
Old Sep 16, 2006 | 04:47 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Which bulb did you use exactly for the step light? The stock step light bulb is ony 7 mm wide, so a 10mm bulb does not fit.
Old Sep 16, 2006 | 04:57 PM
dream_G35's Avatar
"Step light (under door panel)(3175): Super HID White High Power LED Bulb"
The model # is 3175 .....thats all i know. Want a pic of the bulb?
Old Sep 16, 2006 | 05:54 PM
PeteNJ's Avatar
*PICS*:
Meh, output looks weak as it should. These plug in bulbs just suck. No offense. You are better off in retrofitting some Luxeon stars into your housings. I would be REALLY concerned using these plug in LEDs in your backup lights. I am sure you won't be able to see s^*(.
Old Sep 16, 2006 | 07:19 PM
E_K's Avatar
E_K
Sure, or just give me the direct link on that page of the one you got.
