Headlight bulb replacement
Old Nov 5, 2006 | 10:56 AM
Reecard's Avatar
I have an '06 sedan. I am trying to replace the factory fog/high beam bulb with aftermarket. I have read "just loosen a couple of screws and pull down the inner wheel well." Well, I am not sure if an '06 is different, but my inner wheel well is attached to the front bumper and stretches all the way to the center of the car. I took out a few, and I mean 3, screws and the wheel well will not budge. Am I missing something here, am I going to have to remove my front bumper to replace the bulbs? Or just tak out every screw that holds in my wheel well?
Old Nov 5, 2006 | 03:52 PM
Gordgee's Avatar
Administrator
If this is the first time you've done this, it's a good idea to jack up your car, and remove your wheel to get at the wheel well cover. I normally remove the whole cover to avoid possibly damaging it, and/or contaminating the bulb going in there. Besides, It makes it a lot easier to see what you're doing.
AFAIK, the cover should only extend (under the car) to the center engine compartment cover (the one you remove to change oil, etc.), so ends just in front of the wheel well.
Old Nov 8, 2006 | 02:31 AM
avs007's Avatar
x2.
Though you probably don't need to remove the wheel. I just jacked my car up and put it on stands. The wheel will drop down enough to leave plenty of clearance. I just removed all the clips, and about 6 bolts underneath. Enough to loosen the lower engine cover to expose the 2 clips that are hidden underneath it. Once you do that, the wheel-well cover can be pulled straight down.
Old Nov 8, 2006 | 02:36 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
here's the DIY i did a while back. Hope it helps.
https://g35driver.com/forums/body-interior-exterior-lighting-diy/86248-diy-replacing-fog-lights.html
-GP-
Old Nov 8, 2006 | 10:07 AM
Reecard's Avatar
https://g35driver.com/forums/showthread.php?t=86248
-GP-
Great write up, this helps a ton.
Old Nov 8, 2006 | 10:24 AM
nyclifeg's Avatar
Just remeber that in the 06 the top bulb is a low/high beam and the bottom is the fog light only and its a H1 bulb.
Old Nov 8, 2006 | 11:27 AM
Reecard's Avatar
Not on the Sedan, maybe on the Coupe. On the Sedan, top light is low beam and bottom light is fog/high beam. And it is a H4 bulb. If I am wrong someone please correct me.
Old Nov 9, 2006 | 03:28 PM
ckg35's Avatar
I think that the bulb changed from the H4 for the '05+, but I'm not sure.
Old Nov 9, 2006 | 04:15 PM
avs007's Avatar
People are just forgetting that the sedan did not get projectors until 07', so the pre-07' sedans do not use the same bulbs as the 06+ coupes.
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
neight
Aug 2, 2015 03:01 PM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
