double HID's
Old Nov 28, 2006 | 12:47 AM
WRXKiller's Avatar
double HID's
i have 2 sets of headlights adn i was wondering if i could switch out the regular fogs with the hid's so that i have them in the top and bottom areas of the headlight....can this be done with or without a little modification?
thanks
Old Nov 28, 2006 | 01:03 AM
IvoryGT's Avatar
you could use the ballasts from another set of headlight but you will need H4 rebased D2R HID bulbs instead of the one in the low beam of the second set of headlights. This is the only way the factory refector retainers will hold the bulb in place.
Old Dec 5, 2006 | 02:13 AM
G-Mony's Avatar
Has anybody tried this?? Converting our H4 into D2r?? I have a friend bought this for his BMW and he says it works real good.
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:EF:US:11
Old Dec 5, 2006 | 02:35 AM
Calvin's Avatar
Overglorified Altima
yeh it's been done before. so yes it's possible
Old Dec 6, 2006 | 04:23 PM
old_s13's Avatar
http://clearcorners.com/services/#hid
look at the section that refers to the H4 casper shield - those are junk. if you go with a rebased H4 HID setup, expect to have some pretty nappy lighting.
Old Dec 6, 2006 | 09:12 PM
IvoryGT's Avatar
the problem with H4 based HID is that you lose foglight/high beam function, even the ones with such function don't last too long. Thats why some opt for quad projectors.
Old Dec 8, 2006 | 01:39 PM
R2 V35's Avatar
Or you can get this kit..
http://cgi.ebay.com/ebaymotors/True-...58700359QQrdZ1
Old Dec 8, 2006 | 03:36 PM
IvoryGT's Avatar
that is what I was referring to, those use a piece of magnet for the mechanism, it has problems of it getting stuck after prolonged use.
Old Dec 8, 2006 | 09:58 PM
old_s13's Avatar
not to mention, the designers of that fine kit (sarcasm) have not taken into account that halogen lamps and xenon lamps make light differently. therefor, the optics of the lamp are completely WRONG for that bulb. putting an hid bulb in the fog/high beam will do nothing more than create POOR lighting.
just because that flap moves, it doesnt mean that it actually does anything useful. so it shifts the light beam around, big deal.. that doesnt actually create a high-beam. this is much, much different.. than the professionally engineered bixenon 06+ headlamps - atleast with those, the bixenon projector works like designed. those rebased "bixenon" retrofit kits are complete trash.
COMPLETE...... TRASH..... ;-)
Old Dec 9, 2006 | 02:10 AM
G-Mony's Avatar
couldnt be that bad could it??? or at least still better than our stock fogs/highbeam H4 bulbs...
at least the will be more white/blue compared to stock HIDs, and yellow halogens.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
Oregon13
Mar 1, 2016 12:06 AM
BfloG35
Oct 16, 2015 05:22 PM
