trying to get better lights..
I have the stock lights that came with my 04 coupe..
However, those lower fog lights suck, its like brown and ugly....
ANyway i can replace em to something nicer??
aka HID matching lights?
i assume you have stock HIDs? good luck with that..matching halogens to HIDs is not easy and often takes a lot of trial and error a.k.a. lots of wasted money.
try piaa xtreme white or silverstars to match the stock HIDs
if you want blueish lights, then piaa xtreme force.
eh im confused, basically what i want is my fog lights to be blue like my other lights,
my car is 2004 coupe, all stock premium fully loaded..
I dont want brown fog lights.. i want something thats more blue... thats all
Ahero's choices are very good...
The The two attachment pics are my original MTEC superwhite 4350 temp fog/high. at certain angles it looked pretty close.....however, you lost some distance because of the temp...
I also didn't really like the blue look in the reflector all the time....
I replaced them with MTEC Cosmos white 4750 temp.....Here you lose more light, but the coating on the bulb doesn't give off that blue hue....These are pretty close looking as well to the stock HID.....
Hope this helps you out. Heres a pic of the MTEC cosmos white I recently installed
I use the philips blue-vision bulbs. I gave up on matching since its never right and the loss in output isnt worth it.
http://www.powerbulbs.co.uk/
MPG35fiend
Lights
71
Feb 18, 2013 01:43 AM
