Project Prototype
Old Mar 16, 2007 | 01:55 AM
08G37TX's Avatar
LED Sidemarkers Project Prototype (UPDATED!)
Hi guys here is a prototype of some LED corners. Please take into consideration this is a prototype, I am planning on using these in the clear JDM corners, but it doesn't look bad even with the amber lense. These can work in both configurations, both as parking lights and blinkers, or just parking lights.
I have it setup with a 12V regulated voltage supply on board that prevents overvoltage and voltage spikes. This helps the LEDs last longer by not being over-powered. They are current regulated so that the current stays constant to prevent over-saturation of the LEDs and ensures a constant light output. The final fail safe protection on the board is the fuse which is a fast acting fuse to prevent short circuiting. All in all this design has a lot of protection and regulation to make sure that it is stable, safe and long-lasting.
The LEDs are setup in a 4 LED by 4 array pattern. 2 arrays are used for the running lights and the other 2 for the blinker or all 4 can be used for the running light.
I am working on getting a printed circuit board designed for this. and once that is done, it will look really clean...I am going to be moving the regulators to the front of the board and the fuse to the back to make for a cleaner install and allow for easy changing of the fuse if it ever goes out.
Any comments?
Old Mar 16, 2007 | 03:57 AM
kyazh's Avatar
Looks good, but your going to have to take apart the clearcorner every time a fuse blows?
Old Mar 16, 2007 | 12:45 PM
08G37TX's Avatar
That was just they layout of the prototype board. What I am planning on doing is using an inline fuse that you could access through the bulb holder or mounting a TE5 fuse on the back so that it can be accessed without taking the lens apart.
Old Mar 16, 2007 | 12:55 PM
izmir41500's Avatar
G35driver Addict
it looks good with led's, but the fuse needs to be outside of the housing so it's easy to pop off the clear corner and replace it. the fuse also creates a gap in the lighting. continous rows of leds would look way better.
Old Mar 16, 2007 | 01:05 PM
08G37TX's Avatar
That was just the setup of the prototype board. The actual board will either have a TE5 fuse munted on the back or an inline fuse. Both of those can be changed through the hole for the bulb holder so that the housing wont have to be taken apart. The only reason the fuse would ever need to be changed is if the board got short circuited somehow, which shouldn't happen, but this is a failsafe just incase, so the board doesn't get fried and blow the main lighting fuse.
Old Mar 16, 2007 | 01:06 PM
Scootch's Avatar
i use to make stuff like this is school, nice idea man
Old Mar 16, 2007 | 01:09 PM
Mike_Deezy's Avatar
That's looks really good. I'd be interested in that, I've been meaning to find a way to make my sides markers blink.
Old Mar 17, 2007 | 03:21 AM
08G37TX's Avatar
Updates
I removed the fuse since there was a lot of concern about being able to change it. It really was not necessary with all of the other protection that is on this board anyway. I took some new pics of it on a housing back as well as from inside the housing. I also took a video of the blinker functionality which was done by hand and not by the car. This is still a work in progress, but I think once I get the final design down and the printed boards made it will be a simple process to make sets of these for a possible group by if there is enough interest at a fairly decent price, i.e. $100 a set.
Videos:
Old Mar 19, 2007 | 03:20 PM
08G37TX's Avatar
I have completed the design for the PCB and hope to have it sent to manufacturing this week. It am going to hopefully have it made up with a white solder mask and green silk screen to make it almost invisible from the exterior of the sidemarker.
Marlin84
Apr 1, 2020 12:52 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
doakley92
Sep 25, 2015 12:58 PM
TNRocker
Sep 21, 2015 08:36 AM
