Custom guage cluster finally done!
Old Mar 21, 2007 | 01:27 PM
  #31
swiftG35c's Avatar
WOW......that is off the hook!!!!! Great Job!!!
Old Mar 21, 2007 | 01:47 PM
  #32
accordfreak's Avatar
Originally Posted by chanycrazy
So basiclly its easier than older models???
i never got the change to access the LEDs.. but once you do, it should be cake. (taking it all apart)
Old Mar 21, 2007 | 02:31 PM
  #33
Espresso's Avatar
You guys got some great soldering skills. These are tiny SMT LEDs right?
Old Mar 21, 2007 | 02:42 PM
  #34
Deftronix's Avatar
^ Everything in the center cosole, window switch/door locks are smt leds.
For everything else I use a combination of 3mm,5mm,8mm leds.
Seat heater switches - 3mm
Shifter lights - 5mm
Cigarette lighter ring - 5mm
VDC/Dimmer - 3mm's
Gauges - 8mm
Clock - 5mm
Key ring - 5mm
* Random: I wanna also get the 05+ steering wheel so I can do the lit controls
Old Mar 21, 2007 | 03:33 PM
  #35
MidnightG35X's Avatar
VDC/Dimmer - 3mm's
Gauges - 8mm
Clock - 5mm
Key ring - 5mm
What size SMT LED's are they? I'm guessing somewhere around a 0603 or a 0805? Also, how do you take apart the heated seat switch to get to the LED? This is one of those projects I'll get to this summer....
Old Mar 21, 2007 | 07:32 PM
  #36
SagiSRP's Avatar
Nice.. you must have a lot of time on your hand.. I did that to my 00 eclipse before and afterwards didn't feel it was worth the time and hassle because your gauges won't be as accurate as it should be, plus taking it all apart is not fun.. also the blue can tire your eyes out
did you have to use any resistors on the leds?
Old Mar 21, 2007 | 08:36 PM
  #37
Deftronix's Avatar
^^ Actually not all that much. I work full time an hour away from home so that takes up the majority of my time. Plus I have quite a few other things going on.
Making my kitchen my workbench definitely helped out. Multi tasking is key!!
Yes 330ohm-510ohm resistors were used.
I am still trying to get everything to match so I will post exactly where I used which values when its done.
I also did this to my old car as well (lexus gs) and I still find it worth it.
Im just a sucker for blue!
"tire my eyes" - Beauty is pain my friend!
Old Mar 21, 2007 | 09:29 PM
  #38
Wicked_limitz's Avatar
looks nice! Reminds me of AccordFreak custom gauges! good job.
Old Mar 22, 2007 | 08:22 AM
  #39
Larry@Showtime's Avatar
Former Sponsor
WOw.. that looks great.. excellent job!
Old Mar 22, 2007 | 01:23 PM
  #40
swiftG35c's Avatar
How did you get the dash apart where the clocks located?
Old Mar 22, 2007 | 01:53 PM
  #41
Deftronix's Avatar
^^ Thanks guys!!
^ To take the ac lcd/clock out I found that pinching the top part above the lcd on both ends and pulling was the best way. You have to use quite a bit of force, it is quite nerve-wracking. Be careful! Under are 2 screws that are easy to spot. You can esily take it out after.
** I put up another pic on the first page with a better shot of the non led mods on the cluster **
Old Mar 22, 2007 | 02:01 PM
  #42
madchef's Avatar
Looks good....except the mix of orange too....nothing you can do about that right?
Old Mar 22, 2007 | 02:06 PM
  #43
swiftG35c's Avatar
I am going to start on this project this weekend. I am picking up the gells this weekend. I ordered 3 different colors, that way i could see exactly which color i liked....I got Cobalt blue, Diamond Blue, and Tokyo blue.
Old Mar 22, 2007 | 02:44 PM
  #44
RocketG35's Avatar
Why do I bother to DIY???
Where'd you source those chrome rings? Our V8 Touareg has the same chrome ring trim...
Old Mar 22, 2007 | 04:03 PM
  #45
Deftronix's Avatar
^They came as a part of an apc gauge dressup kit for a 94 accord lol (Thanks Accordfreak!). I wanted to retain the full ring and not cut them so I had to shave down the needles slightly, and dremel the clear plastic on the cluster near the bottom (not visible) to fit them (this did not impact accuracy).
I found the kit on ebay. Most sellers will include in the auction notes that they come with the rings
WARNING: Not every auction will include the rings so be sure your not wasting your money!
If you want to look for just the rings, the size of them are 105mm
