another blacked out headlight post
Old May 9, 2007 | 09:19 PM
  #61
gsRt5's Avatar
Originally Posted by ttrank
The only aftermarket ones I have seen are on ebay for the 03/04's. They are black and for the non-HID. I would not trust them...
Thanks, not what I was hoping to hear but oh well...........
Old May 9, 2007 | 09:24 PM
  #62
ttrank's Avatar
Grocery getter
I would just do a TL projector retro into the lower area, paint them and call it done. You can rewire the projectors to be your hi/low.
Old May 11, 2007 | 10:50 PM
  #63
Floyds_racing's Avatar
well I started mine tonight I did a little something extra too!!!
Old May 12, 2007 | 09:53 AM
  #64
killerlexus's Avatar
HOW TO OPEN LIGHTS
1. There are (4) 10mm screws that need to be remove with 10mm socket wrench.
2. Once you pull out the headlights, remove the wire clip that hold it and everything should be completely out.
3. Behind the headlights has a weather seal to protect the bulbs. Remove that by turning counter-clock wise
4. Since i have HID, you should remove ballast by using a phillip screwdriver (3 screws each side)
5. Unclip the ballast and remove the wire from it.
6. Remove all turns/parking light bulbs.
7. i DID NOT remove my HID bulbs. just left them in after i unplugged the haness.
OPENING UP THE HEADLIGHT
1. On your headlight should have small phillip screws around them that need to be remove (forgot how many)
2. Preheat your cooking oven @ 250 degree for 5 minutes.
3. 5 min is up, sit a piece of tin foiled cardboard on top of the plate.
4. Place your headlight on top of the cardboard. (make sure no wires or bulbs are attached
5. Bake your headlight for 5-7 minutes.
6. After 5-7 minutes, remove it from the oven. The silicone should be
melted and gooey. pry the taps along the housing and try to pull the lense apart starting from the corner. make sure to keep the headlights facing up , so no glue will fall on the lense. PITA to get off.may need to bake again for a couple of minutes if it doesnt pull apart easily.
7. While opening, make sure no silicone stick inside your housing. If yes try to clean it off.
PAINTING
1. The chrome housing is held by (2)phillip screwdriver that need to be remove.
2. The orange lense is easy to remove with a dremal.
3. Paint the chrome housing with primer.
4. Once primed you can paint the housing with your paint.
5. do several light coats from different angles.
6. You need to let the paint dry first before putting everything back together.
BACK TO THE OVER!!!
1. Push your headlight back together as much as you can.
2. make sure NO FINGER PRINTS on the inside of the lense.
3. turn oven back on @ 250 degree place the headlight on top of the cardboard for 5 min.
4. Remove it and push your headlight back together as much as your can. then screw back the 3 phillips screw and the 2 halves should tighten together real nice.
5. rebake for 5 min
6. Let it cool before re-installing them.
DOMO no post some picks you ****
Old May 12, 2007 | 11:22 AM
  #65
bert039's Avatar
I think you mentioned it before but I forgot, which was more effective, the retro you did in the upper area or the retro in the lower area?
Old May 12, 2007 | 06:01 PM
  #66
imtheprez's Avatar
Originally Posted by killerlexus
HOW TO OPEN LIGHTS
3. 5 min is up, sit a piece of WET cardboard on top of the plate.
4. Place your headlight on top of the WET cardboard. (make sure no wires or bulbs are attached
PAINTING
BACK TO THE OVER!!!
2. re-wet the cardboard.
3. @ 250 degree place the headlight on top of the cardboard for 5 min.
5. rebake for 5 min
6. Let it dry before re-installing them.
AWESOME DIRECTIONS! one thing though...one putting headlight in oven does it matter how u lay them on the wet cardboard? and did u not sand anything?
Old May 12, 2007 | 11:28 PM
  #67
ttrank's Avatar
Grocery getter
IMO the best bang for the buck is to do a set of TL bi-xenon projectors in the lower area. They are too big for the upper. If you want just the low beams do S2000 or TSX in the upper.
Old May 12, 2007 | 11:29 PM
  #68
ttrank's Avatar
Grocery getter
+1
Very nice.
Old May 21, 2007 | 12:26 PM
  #69
it doesnt matter how the light sits in the oven, just as long as nothing is touching the sides of the oven.
Old May 21, 2007 | 01:35 PM
  #70
redlude97's Avatar
no need for the wet cardboard, dry cardboard will work fine, and the moisture from the wet cardboard will cause steam to condense on the projector lenses
Old May 21, 2007 | 01:39 PM
  #71
ttrank's Avatar
Grocery getter
Good point.
Old May 21, 2007 | 01:41 PM
  #72
IvoryGT's Avatar
what cardboard what?!
heat the oven to 350. then Turn OFF. put the light in. wait 10 minutes. take it out and pry apart. that is the safest way to warm up the rubber putty without melting the plastic.
Old May 21, 2007 | 01:43 PM
  #73
redlude97's Avatar
Do you just set it on the metal rack then? I put it on a baking tray covered in aluminum foil with a piece of carboard so that the thermal conduction due to direct contact is minimal on the backside of the headlight
Old May 21, 2007 | 01:46 PM
  #74
IvoryGT's Avatar
It's fine on the metal rack. It never left a print or anything. The oven actually cools down faster than the part heating up. So around 10 minutes it's just the right time to take out. If not the rubber will just cool off again.
bTanz
Oct 15, 2015 02:31 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
