g35 lights for 2003 vs 2006
Old Jun 14, 2007 | 06:45 PM
panoptio's Avatar
ok guys i am a newbee. I have a 2003 G35 couple and i bought the 2006 oem projection lights on ebay. They dont fit. Are the 2003 and 2006 really different fit or am i just retarded
Old Jun 14, 2007 | 06:48 PM
redlude97's Avatar
Link to ebay post for picture confirmation? They should be a direct swap once you move your ballasts over. Then make sure they are aimed correctly
Old Jun 14, 2007 | 06:55 PM
panoptio's Avatar
are you sure
other than the projector and a bit of wire difference the over all shape and tabs and clips are the same?. It seemed different to me like they dont fit. Can someone that did the switch verify?2003 oem and 2006 oem
Old Jun 14, 2007 | 06:59 PM
redlude97's Avatar
so you took out your stock ones and tried to install the new ones and the holes don't line up? its a direct fit, if you can't get it to work I don't know what to tell you
Old Jun 14, 2007 | 10:36 PM
sfgr415's Avatar
Old Jun 15, 2007 | 09:29 AM
lowrider's Avatar
It is a direct swap. See pics of mine below:
Lou
Attached Thumbnails g35 lights for 2003 vs 2006-hlight-l.jpg   g35 lights for 2003 vs 2006-hlight-r.jpg   g35 lights for 2003 vs 2006-l-hid-proj-h-l.jpg   g35 lights for 2003 vs 2006-r-hid-proj-h-l.jpg
Old Jun 15, 2007 | 09:50 AM
advancetek's Avatar
Looks like a direct swap for me.I will be changing mine today hopefully if i get my bulbs in the mail today.
Old Jun 15, 2007 | 10:23 AM
GreenGoblin's Avatar
The goblin resurrection
it is def a direct swap for the housings did mine no problems at all, just adjusting them took some time
Old Jun 16, 2007 | 07:07 AM
advancetek's Avatar
Just put them on today direct swap did not have to remove the whole bumper to install. Recommend the 5000k phillips on ebay for $70.They a little brighter more white than factory 4300k but looks blue from a distance.
Old Jun 16, 2007 | 09:55 AM
Sooner97's Avatar
Don't waste your money buying new "5000 K" bulbs on Ebay. They're the exact same bulbs as the ones that come in the 06 projectors. The model numbers are the same. I thought they were different too, so I purchased them and when I pulled out the old ones, the model numbers were the same.
Old Jun 16, 2007 | 01:45 PM
sfgr415's Avatar
I installed my flat black TSX colormoded 06's last night/this morning. The process wasn't bad but it did take a while.
I don't know about you guys, but my wire harness did not have more than about 1 inch of slack so it was near impossible for me to unclip the harness to remove the lights. It took me about 30 mins just to do that part alone. I ended up going through the fenderwell. On the 06's, I left the harness loose so if I take them out again, I have at least 6 inches of play.
One thing that was a bit difficult was putting the lights back in because you need to bolt them in correct so you have an even gap all around. I think mine is still off as there is a little gap between the bottom of the left light and the bumper. Not bad, but noticeable compared to the right.
Old Jun 17, 2007 | 05:33 PM
panoptio's Avatar
Thanks everyone. They are a direct swapafter cutting up the harness to wire the projectors. I dont know what i was thinking when i tried to put them in the first time. They fit excellent
Old Jun 17, 2007 | 05:49 PM
lowrider's Avatar
Curring up the harness What do you mean They are a direct swap, no harness modification necessary on USA version.
Lou
Old Jun 17, 2007 | 07:32 PM
sfgr415's Avatar
There should be no cutting at all.
Old Jun 18, 2007 | 02:53 AM
G-Mony's Avatar
Do these fit the sedan? or does the 06 sedan have these lights too?
