home made LED corners, want some opinions
Old Jan 14, 2004 | 10:23 PM
BIGAPPLEVIP's Avatar
had some free time so i made my own LED corner lenses using my existing clear corners. the results were damn good. still need to drive around with them and see how many times i get pulled over before i decide to convert my orange ones.
Old Jan 14, 2004 | 10:29 PM
Re: home made LED corners, want some opinions
the second pic is with the capacitors draining. so you can se the LED. oh yea i want 2 give a thanks to those silly guys at clearcorners.com. got the idea from them. keep up the great work
Old Jan 14, 2004 | 10:31 PM
the pic
Old Jan 14, 2004 | 11:06 PM
Shader7's Avatar
It's hard to tell how blue those are from the pic without the other lights in the array. Post a pic of the corner with the stock Xe on.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 15, 2004 | 04:12 AM
eykim's Avatar
could you post schematic and part numbers?
G35C - 6MT - DG/G - Premium
Old Jan 15, 2004 | 10:40 AM
afr0puff's Avatar
Supa Dupa Moderator
I did something similar, but kept the amber look. It's a row of 11 LEDs, with every other one blinking as a turn signal. They are in a straight line, but the picture throws it off a little. When I have more spare time, i want to make the individual LED dots more pronounced and also match the color of the amber lights on the front of the car.
Did you drill into the back plastic housing, or did you open up the side marker and place the LEDs inside?
http://www.anythingbox.net
Old Jan 15, 2004 | 10:53 AM
OvaYahead's Avatar
dang that is bright. It's warning you that orks are around.
Old Jan 15, 2004 | 02:11 PM
ncozby's Avatar
Afro did you notice that your right wheel fell off?
<font color=blue>04 DG/G Coupe 5AT - St. Louis, MO
Premium, Aero, Performance, Splash Guards
Metallic Tint - 5-Wire Grounding Kit
MB Quart / Eclipse Stereo
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Jan 15, 2004 | 05:46 PM
SFLG35's Avatar
FGC President
more info please. ive been wanting to do this since i saw the ones from clearcorners.com
Daniel
5AT Coupe / DP / Willow / Aero / Premium / 3M Clear Bra / 5% Tint All Round / Ground Kit / Clear Corners / Piaas Everywhere / Shock Sensor
Old Jan 20, 2004 | 07:15 PM
i split the housing and placed a small circuit board with two resistors in between the each LED.
the reason i used the resistors to prevent overloading of the circuit when i arrange the corners to blink with the orange bulb
here is a link to the pics
http://hometown.aol.com/bigapplevip/index.html
also attached are some pics i took with then in the car
and the pictures dont do them any justice. they are much brighter when you se them in person
<P ID="edit"><FONT class="small"><EM>Edited by BIGAPPLEVIP on 01/20/04 04:55 PM.</EM></FONT></P>
Old Jan 20, 2004 | 10:00 PM
afr0puff's Avatar
Supa Dupa Moderator
I know its a lot to ask, but can I see the backside of your sidemarker? Interested in the way you split it open and put it back together. I first sawed off the middle stem that holds the OEM bulb socket. Then I cut out everything between the two connector "prongs." Epoxied the sucker back together and used silicone glue everywhere.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
baker2795
Sep 2, 2015 06:00 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
itschuckster
Jul 25, 2015 08:07 AM
