G35 Coupe Hid Wont Work Help!
Jun 28, 2007 | 12:49 AM
Hey i recently bought 8000k bulbs for my car and put them in they looked great they worked for about a day and than did not turn on at all the next day i thought the ballast went out so i ordered two ballast i put the passenger side one in today and it worked right away than i put the other new ballast in the diver side and it did not even turn on, i tried the old bulbs and the new ones but it still will not turn on can some one help me? and is there a fuse box for the headlights?
Reply 0
Jun 28, 2007 | 07:04 AM
behind the battery
Reply 0
Jun 28, 2007 | 03:26 PM
Arent those only the relays though?
Reply 0
Jun 28, 2007 | 03:28 PM
No, its the fuse box that Infiniti doesn't want you to know about because most of the high dollar items are connected to it.
Reply 0
Jun 28, 2007 | 03:38 PM
YEP, you will need to take off the cowl screen.
Reply 0
Jun 28, 2007 | 03:49 PM
check the relays first...if they are ok then check the fuses in the footwell of the driver side
Reply 0
Jun 28, 2007 | 10:49 PM
do you guys know which one it is becuase it doesnt say
Reply 0
Jun 29, 2007 | 02:31 AM
Hey
Thanks Guys I Found The Main Fuse Box And I Replaced The Fuse And It Worked Thanks For All Your Help
Reply 0
Dec 24, 2012 | 03:10 PM
Where was it located?
Reply 0
