Anyone have a quick Map-light swap how-to?
I buggered around mine with a small screwdriver for a few minutes, then did a forum search, both came up empty. There were plenty of people that have swapped map lights, but none (that I found) with a how-to on it.
Do you get at them from the bottom by removing the lenses?
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
350Z Nismo CAI
Re: Anyone have a quick Map-light swap how-to?
Wow, it's in the owner's manual?
RTFM I guess. Thanks for the tip.
350Z Nismo CAI
350Z Nismo CAI
Use a small flate blade screwdriver to pop the lenses out. They are a little tight, but they will pop out easy. I "think" there is a slight notch in the lens where you put the screw driver. If not, just pop it out on the side closest to the centerline of the car.
BillR
BillR
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
