Custom LED blinking sidemarker
Old Mar 17, 2004 | 05:59 PM
  #31
afr0puff's Avatar
Supa Dupa Moderator
Re: Custom LED blinking sidemarker
With the white LEDs, you can't put more than four in a series. Since there were six for the parking light circuit, I just made three and three connected to the same resistor.
http://www.anythingbox.net
Old Mar 17, 2004 | 06:20 PM
  #32
Gordgee's Avatar
Administrator
So resistor value is about 330 ohms for the 4 LEDs?
<font color=blue>GroundingGear™ Equipped </font color=blue>
Old Mar 17, 2004 | 08:05 PM
  #33
afr0puff's Avatar
Supa Dupa Moderator
I don't follow you about the resistor value for the 4 LEDs. If you were to use 4 of these LEDs, you wouldn't need a resistor. Technically a 27ohm resistor. The Vf is 3.4 and the current is 30ma for one of the white LEDs.
Here are some video clips:
Blinking with no lights
Blinking, lights on.
Old Mar 18, 2004 | 12:10 AM
  #34
Gordgee's Avatar
Administrator
That's what I had to add to my series of 4 LEDs rated at 2500 Mcd@20ma. 1.9V typical, to work with 12V. Current limit resistor rated at 330 ohms.
Old Mar 18, 2004 | 01:21 AM
  #35
afr0puff's Avatar
Supa Dupa Moderator
THe white LEDs are 10,000 MCD. They require more juice than the typical amber once. It was such a pain in the neck figuring out how to neatly arrange the resistors (3). I must have krazy glued my finger to the sidemarker a dozen times while trying to seat them properly. Another thing to keep in mind is that while the car is running, it will put out a max of 14.4 volts through the electrical system after it passes through the alternator. Highest reading I took with a multimeter was 14.1 lowest was 11.8. I calculated with the max voltage so I wouldn't run the risk of a burn out when making them for someone else.
What did you use your LEDs for, the same thing? Got any pictures?
Old Mar 18, 2004 | 12:45 PM
  #36
narkotic's Avatar
Any way you could take a picture of the back of the side marker showing the resistors and the LED's?
VortechSupercharger
TeinBasicCoilovers
Volk 19" GT-7Gunmetal 19x9.5,19x8.5
BridgestoneS0-3 245/35,275/35
EBC GreenstuffBrakePads
RogueEngineeringShort Shifter
NismoGTTitaniumShiftKnob
Old Mar 18, 2004 | 01:20 PM
  #37
afr0puff's Avatar
Supa Dupa Moderator
I shipped the clear pair out yesterday No more pics.
You wouldn't be able to see the resistors since they are all concealed in the bulb socket area. As for the LEDs, just picture the back of LEDs stuck into the plastic housing, covered with silicone, covered with a superthin plastic film. The film is just there to make everything cleaner/neater. Not really required. I may paint the film, but its kind of cool to see the LEDs connected with wires through the sealant.
Old Mar 18, 2004 | 04:37 PM
  #38
Gordgee's Avatar
Administrator
I used them for the the blinkers. Kept the factory bulb for sidemarkers, but I may change something around later.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Gabe83714
Oct 6, 2015 06:40 AM
vamarris
Sep 26, 2015 12:56 PM
