05 to 06 headlight swap
Old Jan 14, 2008 | 11:44 AM
05skylineG's Avatar
so I just got done installing 06 projectors on my 05 coupe. I installed my old HID (D2R) bulbs in the projectors, they seem to be working fine but I was noticing that people on the board were saying to use the D2S bulbs. is there a reason that you need the D2S bulbs??? Do they not shine the same or some how burn up faster??
Old Jan 14, 2008 | 11:46 AM
patman530's Avatar
there is a coating on d2r that prevents glare in reflector housing, that will limit your output in a projector housing. this can be sanded off though. also, to get the d2r to fit into the d2s socket, you will need to create a notch on the base
Old Jan 14, 2008 | 11:48 AM
Calvin's Avatar
Overglorified Altima
d2r bulbs don't fit properly unless you renotch them and scrape the ceramic coating off them.
Old Jan 14, 2008 | 11:52 AM
05skylineG's Avatar
is the coating see through cause both bulbs look pretty close to the same. also when I put my old bulb into the new housing it fit in just fine, i just spun it until it dropped in then locked it in place. How would I sand the coating off and is it worth just buying some D2S bulbs?
Old Jan 14, 2008 | 12:03 PM
patman530's Avatar
the coating should be dark, the purpose is to block light. and you should not be able to fit the bulb in without creating a new notch. maybe you already have d2s bulbs for some reason? does it actually say D2R on the base of your bulbs?
Old Jan 14, 2008 | 12:08 PM
patman530's Avatar
this might help: http://faqlight.carpassion.info/hl-hid-bulbs.htm
Old Jan 14, 2008 | 12:18 PM
05skylineG's Avatar
thanks for all the info. I bought them off a website, all they say on the bottom is Japan. the notches are different then the bulbs (d2s) I got with my projectors, but they do fit right in still. I’m going to have to just buy some d2s bulbs. any recommendations on where I can get some 8K bulbs for a decent price. how are the bulbs off of HIDplace.com?
Old Jan 14, 2008 | 12:21 PM
patman530's Avatar
stick with the OEM brands like Philips or Osram, I recommend stock temps (4300K) but if you want to go higher, I would say go with the Philips Ultinon 6000K at the most. 8000K bulbs are dim look ricey
Old Jan 14, 2008 | 12:29 PM
05skylineG's Avatar
looking my bulb that I had in my old headlight there are some letters that are engraved, here is how they read. ML-D2C-D4. it has 5 notches on it instead of just the 2 notches like a stock bulb. the bulb is clear, no paint/coating on it at all on the lens. It must be a universal bulb or something
Old Jan 14, 2008 | 12:36 PM
Calvin's Avatar
D2C bulbs fit in both D2R and D2S fitments. That's why they fit.
Old Jan 14, 2008 | 01:26 PM
Boston's Avatar
+1 on the Ultinon 6000K. The loss of output on the 8000K will be signifcant and users with them have noted problems in the rain.
alessandro
Oct 8, 2015 09:29 AM
doakley92
Sep 25, 2015 12:58 PM
