Interior Light Dont Work Need Help
Old Jan 19, 2008 | 01:35 AM
awong's Avatar
Dash board light, steering wheel light, clock light, glove department light, license light, and corner lights DO NOT WORK AT ALL what is the problem and how can i fix it?
Old Jan 19, 2008 | 11:47 AM
g35freak86's Avatar
most likely blew a fuse. check the fuse box and replace ones needed
Old Jan 19, 2008 | 06:13 PM
awong's Avatar
well if my Dash board light, steering wheel light, clock light, glove department light, license light, and corner lights goes out do i place 10?
Old Jan 19, 2008 | 07:46 PM
g35freak86's Avatar
Nah because not every light has a seperate fuse
Old Jan 20, 2008 | 01:37 AM
awong's Avatar
**** man i guess ill bring it to a body shop man or bring it to infiniti and how much would it cost if i brought it to infiniti damn this shiet hella pisses me off
Old Jan 20, 2008 | 02:39 AM
W203's Avatar
You do not need to go to a body shop for this...
Look in your manual for the fuse number and replace it.
Old Jan 20, 2008 | 03:37 PM
awong's Avatar
the manual dont even show this thats the problem and do you think infiniti will warrenty this?
Old Jan 20, 2008 | 03:50 PM
g35freak86's Avatar
Check the fuses man and reaplce the ones neccesary. It will take 3 minutes
Old Jan 20, 2008 | 03:59 PM
Corvettekid's Avatar
The fuse box is located under the steering wheel to the left. Just take 3 minutes like he said and replace the blown one. OR, disconnect your battery for a few minutes and then reconnect. THat seems to be a common problem when replacing the interior lights.
awong's Avatar
yeah i tired man im fuking up even more and i think i friend put some of the fuses in the wrong spot also =( man its killing me man
Old Jan 20, 2008 | 04:02 PM
g35freak86's Avatar
I understand that little things like this can be frustrating. However, if you take the time to learn and read the manual, this problem will be 110% less stressful. Go to your manual, find which fuses that you need to replace, and do just that. If you are confused, come back here and explain and we can help you provided pictures and a description
awong's Avatar
checked man non of the fuse seem blown at all =( what should i do?
Old Jan 20, 2008 | 04:50 PM
did you disc the battery and reconnect it?
Old Jan 20, 2008 | 04:59 PM
awong's Avatar
if i do that then all the thing will be reset and i dont want that to happen i guess ill probably take it in to the dealer ship tomorrow and have them check it out and maybe they will fix the problem and i doubt and hopefully it would be much
Old Jan 20, 2008 | 05:14 PM
Wow.. So let me get this straight. Instead of taking the 4 seconds to disc the battery and reconnect it and have everything work again, you will take it to teh dealer so THEY can do it and youll STILL have to reset everything? Why do you own a car? GO back to horse and buggy...
