2006 head lights question help please!!!
Old Jan 26, 2008 | 06:48 PM
Graphic35's Avatar
i have bought projectors of ebay everything seems fine
but i have a small question i put my new 8000k hid bulbs in went in fine but where is the cable that connects to the hid bulb it self? does that cable comes from the ballest?
im preety sure it should be right in the had light here is a picture with the hid bulb installed already all i want to know is where the cable that connects to the HID BULB
Old Jan 26, 2008 | 08:07 PM
Graphic35's Avatar
anyone?
Old Jan 26, 2008 | 09:26 PM
ON's Avatar
ON
I'm assuming you are referring to the ignitor. Im assuming you are reusing your original ballast, so just reuse the original ignitor as well. Just disconnect it from the ballast and pull it out and route it through your new headlights. Bada bing bada boom, Done.
Old Jan 26, 2008 | 10:25 PM
IvoryGT's Avatar
yeah you will need the original bulb connector and the ballast from your old headlights.
Old Jan 26, 2008 | 10:27 PM
Graphic35's Avatar
is it easy to take out and connnect it back to the new housing?
Old Jan 26, 2008 | 10:29 PM
jlinc04's Avatar
yup, it should be one Phillips screw...for a wire & like 3 screws for the ballast...
Old Jan 26, 2008 | 10:48 PM
Graphic35's Avatar
what if the head lights i got are recalled what do i do??
Old Jan 27, 2008 | 02:29 PM
ON's Avatar
ON
https://g35driver.com/forums/body-interior-exterior-lighting-diy/172562-diy-ballast-switch-06-headlight-upgrade.html
post #11
https://g35driver.com/forums/body-interior-exterior-lighting-diy/160947-diy-how-properly-aim-06-coupe-projectors.html
Old Jan 27, 2008 | 05:48 PM
jlinc04's Avatar
Correct me if I'm wrong G owners, but I believe the recall headlights are dealing with the aiming issues...
mike730
Jan 12, 2018 04:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
