Difference between 2003-2005 vs 2006 headlights
Old May 8, 2008 | 11:13 AM
  #46
IvoryGT's Avatar
I have a kit available for coupes.
Old May 8, 2008 | 11:27 AM
  #47
badassflip's Avatar
IvoryGT,
I have an 04 coupe with the 06 projector housing. I've been using the 8000k D2C bulbs (fits both D2R and D2S housing) for about a year and a half. the driver side bulb just burn out yesterday. I am thinking getting a pair of the D2S bulbs. would they fit my 04 coupe?
If they do, where would you recommend to purchase them?
Old May 8, 2008 | 11:38 AM
  #48
IvoryGT's Avatar
D2S bulbs will fit the 06 lights. are you looking to go back to factory spec?
Old May 8, 2008 | 11:40 AM
  #49
Mr Inkredibul's Avatar
Originally Posted by sxexcx
+city lights
-clearance lights
-orange blinker lense
What are city lights? and you are saying that the 06 has them?
Old May 8, 2008 | 11:46 AM
  #50
badassflip's Avatar
well, are the factory D2Ss 6000k? I would prefer the 6000ks. would it be cheaper to go factory spec?
Old May 8, 2008 | 11:58 AM
  #51
IvoryGT's Avatar
factory is 4200K. It wont be cheaper to go OEM because they last way longer.
Old May 8, 2008 | 12:03 PM
  #52
badassflip's Avatar
where should I get the D2S 6000k or 8000k? do you sell them yourself?
Old May 8, 2008 | 12:17 PM
  #53
IvoryGT's Avatar
I don't sell the bulbs above 5000K for various reasons, if you must, try looking up the Philips 6000K ultinons around the web.
Old May 8, 2008 | 01:16 PM
  #54
badassflip's Avatar
thanks for you your help! Im gonna go ahead and buy the Philips 6000K ultinons. just one last questions. when I bought the 06 headlight, it was just the housing. I got the D2C bulbs because it fits my 04's harness. my question is, Is the D2S bulbs drop in plug n play? or only the D2R will fit my harness?
thanks a million.
Old May 8, 2008 | 01:18 PM
  #55
IvoryGT's Avatar
D2S is for projectors only. so it will fit. If you had D2R bulbs it wouldnt work.
Old May 8, 2008 | 01:35 PM
  #56
badassflip's Avatar
Thanks again. So the different base notches of the D2R and D2S wouldn't be a problem. arite, im ordering them.
Old May 8, 2008 | 02:39 PM
  #57
IvoryGT's Avatar
you have the projector lights so the notch is for D2S. the older lights that came stock on 04 has D2R notches. the D2C you had allowed the interchange.
Old May 17, 2008 | 07:46 PM
  #58
DREPDOM's Avatar
i have a 03 sedan and i'd like to know if the 06 2dr projector will fit mine w/o modification?
Old May 18, 2008 | 10:14 PM
  #59
dev1983's Avatar
I don't think 06 projectors will fit your sedan...sorry
Old May 22, 2008 | 07:35 PM
  #60
mIKE's Avatar
Because techs know everything right
if G35s are too bright then every TL and every S2000 owners need to throw their headlights away. Because G35 output is mediocre compare to either one of them. go drive next to one and you'll find now what bright means.
They were recalled for glare, I bought a pair that had the exact reason why they needed to be recalled.
s2k's are not bi-xenon
