LED Replacement Questions
Old Jun 28, 2008 | 02:01 PM
  #106
GBeast's Avatar
Originally Posted by elayman
^ make sure you install them with the lights off and put them back in the hole before turning the lights on.. i think i blew one that way and i blew the rear light fuse, which is located behind the battery ;(
will do, thanks
Old Jul 3, 2008 | 02:31 PM
  #107
rock35's Avatar
hey guys are these the 6mt 31mm festoons you used for the under doors and domes?
http://www.v-leds.com/Shop/Control/P...35248245250239
the other link on page 1 didnt work anymore.
also my unlock door button light is dead, how do i change that?
Old Jul 3, 2008 | 02:40 PM
  #108
elayman's Avatar
the link you posted here doesn't have festoons.. check these out
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
or something with more smt bulbs would work and be brighter.. you need ones shaped like that though
Old Jul 3, 2008 | 02:52 PM
  #109
rock35's Avatar
ahhh sorry didnt know what festoons were.
question though. on the sylvannia guide and on a sticky in here it says
step/courtesy lights are DE3022 (not sure what this means except obviously shape/style)
but the link you posted has
SUPER WHITE 9 LED DOME LIGHT BULB 212 211 212-2 214-2 578
shouldnt these numbers match?
i found the license plate light mentioned here
HID WHITE HIGH POWER LICENSE PLATE LED BULB 194 168 158
the 194/168 matches the guide.
see my confusion? =)
i just want super bright, i guess SMT cool white leds for
under door(courtesy lights)
dome/map
and license plate.
Old Jul 3, 2008 | 02:56 PM
  #110
rock35's Avatar
i may have courtesy lights mixed up with something else.. looks to be something for an RV?
Old Jul 3, 2008 | 03:00 PM
  #111
rock35's Avatar
only thing i could find
http://www.v-leds.com/Shop/Control/P...31242251246245
Old Jul 3, 2008 | 03:39 PM
  #112
stradaONE8's Avatar
the interior and door lights are Festoon based, ie look like they have cones on either side of the bulb
Ie, they look like this bulb, but use SMT LEDs (the yellow plates) instead of LED bulbs.
Should be under code DE3175-3175, but are out of stock or something because I haven't seen the bulbs I used for a while now.
Old Jul 3, 2008 | 04:37 PM
  #113
rock35's Avatar
hi im having trouble finding 6 SMT festoon 31mm anywhere.
does it HAVE to be 31mm? I'm assuming yes since 3022 and 3175 or whatever is probably a length.
Old Jul 3, 2008 | 05:04 PM
  #114
stradaONE8's Avatar
^ yea, they aren't on the website right now for some reason...I don't know why.
And yes it has to be 31mm to fit in the housings we have.
Old Jul 3, 2008 | 05:35 PM
  #115
rock35's Avatar
thanks alot. i hope 6 smt's isnt going to be ridiculously bright =)
http://cgi.ebay.ca/1pc-31mm-3022-3175-6-SMD-LED-White-Festoon-Bulb_W0QQitemZ190233698919QQihZ009QQcategoryZ33713QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
think i'll just get these.
Old Jul 3, 2008 | 06:16 PM
  #116
rock35's Avatar
hey guys. wondering if these "flank" leds were better for the license plate lights or if the regular ones are better
Flank
http://cgi.ebay.ca/2pcs-168-194-Flank-High-Power-LED-White-Wedge-Bulb_W0QQitemZ190233961324QQihZ009QQcategoryZ33713QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
vs.
Normal like the VLED on that was linked.
http://cgi.ebay.ca/2pcs-168-194-1W-High-Power-LED-Xenon-White-Wedge-Bulb_W0QQitemZ200236004383QQihZ010QQcategoryZ33713QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Old Jul 3, 2008 | 07:25 PM
  #117
Rhino_111's Avatar
My only advice is stick with a reputable company such as Vleds.com. I have heard many horror stories of LEDs from Ebay that only last a matter of days before dying. All my LEDs are from Vleds and no problems yet. Just my 2 cents.
Old Jul 6, 2008 | 08:39 PM
  #118
Cobra-2-G's Avatar
Just FYI: you can use the coupon code "miata" for 10% off the V-Led site
Old Jul 17, 2008 | 11:33 PM
  #119
rock35's Avatar
I have no idea how to pop these caps off the lights.. ahah i dont want to break anything
wish me luck.
Old Jul 17, 2008 | 11:56 PM
  #120
rock35's Avatar
wish me luck.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
