Hey guys, I just got some 07 headlamps and bought 4 d2s because i thought it needed 1 for low and 1 for high. But there is only 1 hole. Does it use the same bulb for low and high?
Yes, it uses one bulb for both the high and low beams. It has a shield inside the projector assembly that changes the cutoff from low to high beam.
damn now i have two extra bulbs. lol also do you know where the green ground wire plugs into that is attached to the d2s bulb socket?
Quote:
They are the oem philips 85122+ d2s bulbs. The + means they burn at 5000k.Originally Posted by crashnburn
id buy ur extra set... what the color range on it? 4500k 6000k or 8000k?
Ill sell them for $45 for the pair plus shipping.
