How's my cutoff?
Old Oct 31, 2008 | 08:31 PM
2001Z71's Avatar
How's my cutoff?
I just installed my colormodded projectors done by IvoryGT. I followed the great DIY aiming guide (thanks redlude97!) and wanted to see what you guys think of the cutoff, does it look OK?
From 25ft on level ground:
with fogs:
Cutoff still at 25ft:
Close up to the "wall":
Far away:
Driving:
One concern I have is that the driver fog light is a lot lower than the passenger. Is that normal, or can I adjust it?
Old Oct 31, 2008 | 08:44 PM
redlude97's Avatar
it seems like you have some sloping issues with your projectors, and they need some rotational adjustment. Maybe try loosening up the 4 bolts and rotating the headlights to even them out some, then re aim
Old Oct 31, 2008 | 08:49 PM
2001Z71's Avatar
So just loosen the bolts, and rotate them left and right until they're more even?
Old Oct 31, 2008 | 09:03 PM
g35man04's Avatar
CLUB MODERATOR
where is the post up of how to aim them the correct way...I think mine are pretty bad
Old Oct 31, 2008 | 09:08 PM
2001Z71's Avatar
DIY section
Old Oct 31, 2008 | 11:12 PM
2001Z71's Avatar
https://g35driver.com/forums/body-in...rojectors.html
Old Oct 31, 2008 | 11:42 PM
2001Z71's Avatar
I played with loosening the top bolt and I got the cutoff a bit more even, but I think Im going to get it perfect next weekend when I have time to take my bumper off. I also found the fog light adjuster so I got those straight too.
redlude97
132
Jan 7, 2016 02:10 PM
IvoryGT
323
Feb 23, 2015 08:59 PM
Dem1K
Lighting
Feb 10, 2008 11:39 PM
