HID flickering lamp
Old Jan 6, 2010 | 08:47 PM
kidtronix's Avatar
Optional
HID flickering lamp
Old Jan 7, 2010 | 10:04 AM
twarsop's Avatar
I'd check your connections, specifically your ground, but here is a good website with some info.
http://lampday.com/index.php/news/view/11.html
Old Jan 7, 2010 | 10:44 AM
twarsop's Avatar
I would highly doubt it has to do with your battery since it's not consistent across the board (or even the other light). Bad battery is going to effect the entire system, not just a single ballast.
Old Jan 7, 2010 | 12:34 PM
3crchino's Avatar
I agree with twarsop, sounds like a bad ground. If it were a bad batter that wouldn't be the only problem you would be having, you should get a circuit tester and see if any power is going thru your ground.
Old Jan 7, 2010 | 08:37 PM
dave's Avatar
Shortly after I installed mine, I had a problem where the JDM HID fogs would turn themselves on in the rain. They stayed on even when I set the switch to use the in-headlamp fogs.
I solved it by putting the relays in a waterproof enclosure. Maybe you are getting water somewhere. Has it rained lately?
red35
Feb 17, 2023 09:48 AM
nhbfighter
Interior
Mar 13, 2009 11:13 AM
osamabinwayne
Nov 1, 2005 11:32 AM
