Flickering Projector
Old Jan 6, 2011 | 11:28 PM
g3fly's Avatar
So check it. I bought new projector headlights off some dude. Hooked up the headlights with my balast (off my 1st gen non projector headlights) and his bulbs. I went and installed the headlights on the car then I go turned them on and the driver side headlight flickers on then turns off. Took em out checked the wires and conections and the ground on the fog light wasnt pluged in. Pluged it, then tried it again. Did the same thing, flickerd on then turned off (the right headlight worked fine btw, also the amber and fog light worked on the left one). So I assumed it was the balast so I swithced them around left to right right to left... Still did the same thing. So my question is; Do I need a new D2S Bulb? or am I forgetting to check something? I honestly dont think its the bulb because it flikers on then cuts out, if it was out it wouldn't go on at all right?
Old Jan 8, 2011 | 11:54 AM
the04coupe's Avatar
could be either the bulb or the ignitor . Bulbs will flicker for a while before they totally die . The ignitor is notorious for loose connection
Old Jan 8, 2011 | 12:20 PM
g3fly's Avatar
aright ill check out the ignitor. Ay do you know if our oem balast are 35w or 50w ballasts?
Old Jan 8, 2011 | 12:48 PM
the04coupe's Avatar
All oem ballasts are 35w .
Picture Share
Feb 4, 2018 12:41 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
G35xdriver04
Nov 7, 2015 08:31 PM
MrIP35
Oct 25, 2015 11:13 PM
