glove box, help!!!
Old Jan 19, 2011 | 01:11 AM
xxxxxxxxxx's Avatar
Unhappy glove box, help!!!
so im trying to change the glove box bulb, and no luck
i don't know if im doing it right ,im trying to take if out with my fingers, but i cant get a good grip, my fingers keep slipping , is there another way to change the bulb?
this is what im talking about.
Old Jan 19, 2011 | 02:52 PM
saywat?'s Avatar
cant u jus stick a flat head screw driver in there and pop out the cover?
Old Jan 19, 2011 | 02:55 PM
G35SedanGrn's Avatar
same, i scratched the fvck out of the cover & gave up for now.
Old Jan 19, 2011 | 02:59 PM
xxxxxxxxxx's Avatar
yeah i could take out the cover, im talking about taking out the bulb thou
Old Jan 19, 2011 | 03:02 PM
saywat?'s Avatar
maybe some tweezers or longs nose pliers or 6 year old child ?
Old Jan 19, 2011 | 03:03 PM
sillyoldtayo's Avatar
i used needle nose pliers i think
Old Jan 19, 2011 | 03:05 PM
g35man04's Avatar
CLUB MODERATOR
you have to drop down the whole glovebox...on the backside of that area in by the ECU there is a lock-in harness that you rotate and pull out. you can then access the bulb...replace it and put the harness back in place. Its the easiest, less stressful and takes all of 30 mins.
I wasnt able to get a pair of needles nose onto the bulb and pry it loose without breaking..maybe having some rubber pading on the end for grip like the old ROBO GRIP pliers would help...
First off remove the bottom tray piece by just pulling down on it and out. there should be 2 clips on the front side and there are grooves on the back that fit into place at the firewall area. Pretty self explanatory.
On the glove box to drop down..you must take out the passenger side plastic trim on the foot area. should just pop straight off. At the back side up against the firewall on the inner kick panel there is a plastic nut..un-screw that piece first. you then have to remove the inner passenger kick panel with a flathead. Pull back the weather stripping first and you should be able to see an area to place a flat head in there.
once popped off there is a screw inside of that area that holds the glovebox in place..should be right above the lower kick panel clip in plain sight. there will be a second screw on the bottom side to the left. take that out as well. Then lower down the glovebox and you should now see 4 screws. 1 to the left and 1 to the right and the 2 holding on the metal ring that the glovebox locks into. take out all 4 of those...no order needed. you then should be able to apply some pressure to the glove box door and pop it loose. This will then allow you to access the backside of the Glovebox light area that you can just turn loose the harness and replace the bulb.
to install just repeat steps back forward.
hopefully that helps.
Old Jan 19, 2011 | 05:08 PM
xxxxxxxxxx's Avatar
^^ thanks to that i did it and installed my led
Old Jan 19, 2011 | 05:12 PM
g35man04's Avatar
CLUB MODERATOR
Glad I could help! Maybe I should DIY this for led installs or Ecu access
Old Jan 19, 2011 | 06:17 PM
MikeDG's Avatar
There are DIYs in the Audio,Video, Electronics forums that show how to take apart the glove box for DD installs. Also, this thread has a couple of videos that show how to disassemble the glove box in the DD install and in-cabin filter replacement vids.
https://g35driver.com/forums/g35-sed...eo-series.html
Old Jan 20, 2011 | 01:06 PM
RicoG35x's Avatar
yeah.. that GB lamp puzzled the crap outta me as well, when i first looked at it.. thought the bulb was connected to a plastic housing that plugged into the connector... then after looking at the replacement diagrams in the Tech/Service manual.. i realized.. it was simply the bulb plugged into the whole connector assy.. i used one of those rubber lid remover things that they pass out with insurance salesman crap on them.. gripped it.. and ripped it.. BAM!... the bulb came out.. dropped in my VLEDS replacement.. direct fit..not muss no fuss.. looks AWESOME!
All i have left is the ash tray bulb... VLEDS no longer carries White T-4 replacements.. only T-5's.. :/
Old Jan 21, 2011 | 05:23 AM
VincenzG35's Avatar
What bulb fits in there?
Old Jan 21, 2011 | 06:59 AM
RicoG35x's Avatar
This is what I used... fills the GB with nice even white light.. especially with the side firing LEDs as well as the front firing led... full coverage.. tried just a front firing type.. not enough light.. too directional.
http://www.v-leds.com/Interior-LED/G...-p6298403.html
Old Jul 12, 2013 | 05:45 PM
myleskeller's Avatar
sorry to raise an old thread from the grave, but that link is dead.
is there a typical bulb size i could use to cross-reference with an led vendor like superbrightleds.com?
Old Jul 26, 2013 | 02:17 AM
SpeedFreek34's Avatar
Lightbulb T5 / 74 LED Bulb
I went to DDM Tuning and used the T5 / 74 LED bulb.
http://www.ddmtuning.com/Products/T5-LED
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
