HID Fog Lights Advice..
Old Feb 1, 2011 | 11:01 PM
carlo107's Avatar
Hey everyone,
I purchased a black on black 07 g35 coupe not too long ago and I have decided I want to start changing some parts. I have been searching the posts quite extensively and havent been able to find any photos that can give u a clear picture of what hid fogs with stock projectors for the headlights look like.
Rather than asking everyone to post pics I am more interested in knowing a few things about getting HID fog lights:
1. Being an 07 coupe I have projectors for my headlights. I want to know from those of you who have hid fogs installed with the projector headlights if the fog lights overpower the look of the headlights because they are not in a projector? Can you visibly see both lights or is the light from the fog lights all you see?
2. Also I am planning on changing my Hid headlights to either 6000K or 8000K and am thinking of putting 3000K in the fogs. What do people think of this mixture being on a black car or do people think it would be better to get matching temperatures?
Thanks in advance for the replies and I know it is hard to tell in pics of exactly what it would look like but if anyone does have some clear pictures and would like to share them it is much appreciated. Thanks again.
Old Feb 1, 2011 | 11:04 PM
DEEZBLUBALLZ's Avatar
I tried 3k for my fogs, looked weird. Even had 3k headlights at one time. Settled on 8k on headlights and fogs......thats what i recommend.
Old Feb 1, 2011 | 11:13 PM
carlo107's Avatar
Ok thanks for the advice I had 8k in both my headlights and fogs on my last car but I thought I would change it up a bit I can always just buy both bulbs and one set of ballasts and see which I like better but that's kind of a waste of money. Any other suggestions?
Old Feb 2, 2011 | 01:36 AM
Da_KiiD_cT's Avatar
+1 for matching temps, it just looks better
Old Feb 2, 2011 | 03:12 AM
develop1's Avatar
Just like DEEZBLUBALLZ, I have 8k projector headlights and fog lights. The fog lights do not over power the look of the projectors. They look equal in emitting the same amount of light/power. I, too, suggest matching temps. Having 8k projectors with 3k fogs will look weird because they're in the same housing. The only way this will work and look good if you put external 3k fog lights under the grille. Just as everyone else has mentioned, just my opinion.
Old Feb 2, 2011 | 09:58 AM
Raven088's Avatar
I agree with DEEZBLUBALLZ as well. I had 3000K Ion bulbs in my fogs/hi's for a year or so, then upgraded with a Bi-xenon H4 hi/lo 8000K kit. I still have the full use of my fog and hi beams. Color match is the best way to go.
Old Feb 2, 2011 | 10:44 AM
carlo107's Avatar
Ok I guess matching is the way to go then is there any particular brand of lights that you recommend to buy or are they all the same?
Old Feb 2, 2011 | 12:54 PM
Raven088's Avatar
Check this site out: http://www.xenonempire.com/s8000k.htm
I've used kits from them before. Follow the link, and under the "Select Your Vehicles Bulb Below" tab, scroll to the H4/9003 Bi-xenon option. I used a different brand, and the only reason i am recommending this company is because the supplier i use is out of stock.
Old Feb 2, 2011 | 01:12 PM
VincenzG35's Avatar
do fogs take a regular hid kit or are there ceratin ones for fogs
Old Feb 2, 2011 | 01:36 PM
Raven088's Avatar
If your fog/hi housing says H4,HB2/ or 9003, you must install the H4 Bi-xenon hi/lo HID kit for full use of your fog, and hi beams, otherwise you'll lose functionality of one or the other if you just get a normal H4 HID kit.
Old Feb 2, 2011 | 01:47 PM
VincenzG35's Avatar
I have the stock 4300 hids with what I believe is the h1 bulb in the fogs
Old Feb 2, 2011 | 01:54 PM
Raven088's Avatar
I'm pretty sure our fog/hi's are HB2. Keep in mind that H4,HB2, and 9003 are different names for the same bulb.
Old Feb 2, 2011 | 02:28 PM
carlo107's Avatar
Thanks for the input everyone yeah vincenzg35 if you have the stock projectors our fog lights take an h1 bulb not an h4.
Old Feb 2, 2011 | 02:56 PM
VincenzG35's Avatar
Oh I have an 03
Old Feb 2, 2011 | 03:19 PM
Raven088's Avatar
Oh I have an 03
If your car did not come factory with HIDs then you will have H1 bulbs for the low beams. Fogs and hi's will still be HB2, H4, or 9003. Here is a link for the list of the factory bulbs for your car.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
carlo107 is correct for the 06 and above models i believe.
