changed ballast, still no light!
Old Mar 7, 2011 | 09:39 AM
VegasG's Avatar
I have an 06' coupe. First the passenger headlight was flickering then went out completely. I read that to find the route of the problems, swap the bulb with the other side to see if that solves the problem. Swapped, and the light still worked (on the driver side). So then I swapped ballasts. Now both sides dont work. I swapped the ballasts back and they still both dont work. So, Im trying to figure out what i did wrong. All wires were back in place and secured everything the way it was initially. Is there something I forgot to do? Anyone experienced in this area? Thanks in advance.
Old Mar 7, 2011 | 10:18 AM
VegasG's Avatar
Having a hard time isolating the problem. If it was the wire, swapping ballasts, the driver side should still work. If it was ballast, passenger side should work. I did initially check if the bulbs worked as well, and they did. Fuse maybe? Fuses go out when swapping ballasts?
Old Apr 12, 2011 | 08:44 PM
dreamweaver's Avatar
i have similar problem but noone seems to know headlight issues
VANST3R
Lights
Jul 27, 2015 08:20 PM
mjfenix
Jul 24, 2015 05:16 PM
ClwMike
Jul 23, 2015 12:55 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
