Both reverse lights are out!!!
Old Nov 12, 2013 | 04:26 PM
WhosUrBuddiee's Avatar
A/T
M/T
Old Nov 12, 2013 | 04:29 PM
BTW, the IDPM is behind the battery.
Old Nov 12, 2013 | 05:13 PM
Austin8868's Avatar
Originally Posted by WhosUrBuddiee
Anyone what?
It isnt missing. 6mts dont use a reverse relay, it gets feed directly from transmission. Only 5Ats have a reverse relay.
Refer to electrical service manual.
http://psedog.com/cars/fsm/g35/coupe/2004/lt.pdf
Just wondering if anyone knew why the reverse lights would be out. I have a 5at. I checked where the grommet is to see if the wires were cut but they were fine.
Old Nov 12, 2013 | 06:41 PM
I already posted the service manual and wiring diagram. It is either the relay, the fuse, or the bulbs. Check each one by one, if all are ok, then you have a ground or loose connection somewhere.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
youngdip631
Lighting
Aug 31, 2015 09:13 PM
ghost_g35
Aug 7, 2015 10:31 AM
