Dual action/color parking lights
Old Jul 21, 2011 | 03:32 AM
rdeverett's Avatar
I'm not sure how to search for this so I'm just making a thread. I plan on buying 06 projectors soon for a number of reasons, one of which is the clear parking lenses. I was wondering if it's possible (or if there's a bulb) to have the parking lights shine white when they're on, then blink amber when your signal is on. I realize you could just have them blink white but I try to stay within the legal boundaries whenever possible.
Old Jul 21, 2011 | 03:39 AM
Spitfire91104's Avatar
06 projectors do not have a lighted clearance stripe. Only bulbs that light up with parking lights are side markers and little wedge bulbs in the fog housing. Wish the clearance strips lit up like on my old 03 lights.
Old Jul 21, 2011 | 04:21 AM
rdeverett's Avatar
I may not have been clear enough but I wasn't referring to the clearance strips. I'm referring to the smaller circle lights next to the fogs. In the 03-05 headlights, they have an orange lens. In the 06-07 headlights they are clear (the blinkers).
Old Jul 21, 2011 | 04:51 AM
LEDmarkers's Avatar
Our switchback modules will do what you want however it requires both a white and a amber LED array with both being isolated . We can make a plug in LED bulb which can function with our switchback module but the turn signal part would not be bright enough by itself. If your using it with the oem turn signal and just want to give a little extra glow for the turn signal it will be fine .
Old Jul 21, 2011 | 08:23 AM
0MGHI2U's Avatar
i did it to my 06 headlight (turn signals) for less then 50 bucks..
https://g35driver.com/forums/g35-cou...-housings.html
Old Jul 21, 2011 | 09:51 PM
rdeverett's Avatar
Thank you'll for the info.
0MGHI2U that's exactly what I was looking for. Since the link for the bulb in the DIY is old, is this what I would need?
http://www.v-leds.com/Exterior-LED-B...-p7114832.html
Also, the DIY write up wasn't very thorough so I'm kind of confused. I will have a spare set of 03-05 headlights after I buy the projectors, so do I just need to retro fit the 7443 plug into the new headlights?
Finally, when you turn the blinker on, does it alternate between white, amber, white, amber? Or does it alternate between amber, off, amber, off? Sorry if that's confusing.
Old Jul 21, 2011 | 11:01 PM
sTeadFasT96's Avatar
I'm not sure if it matters but you do realize that bulb you have linked is a 3157 bulb and not a 7443.
Old Jul 21, 2011 | 11:11 PM
rdeverett's Avatar
Yeah I noticed that too but couldn't find a 7443 bulb. I just looked again and I think I found the correct bulb.
http://www.v-leds.com/Exterior-LED-B...-p7589718.html
Old Jul 21, 2011 | 11:17 PM
That's more like it. I was on a search today for the same bulb but in 5k but they don't have it
Old Jul 21, 2011 | 11:22 PM
rdeverett's Avatar
5k is exactly what I'm looking for so I think I need to look at some other sites. Also, some people were complaining that the 48 smt bulbs weren't bright enough in the day time when the ambers are on. I guess it's google time.
Mry
Mar 3, 2023 01:03 AM
mtlruss
Dec 20, 2015 01:51 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
