~TunerMax's RF Controlled Colour Changing LED Project~ PIC HEAVY
Old Jan 17, 2012 | 01:06 AM
HeelToeSTi's Avatar
Good work man. I love good personalization like this. Can't wait to see it all finished.
One thing: it looks like hairs got into your clock (lint?) as well as some dust? I know when I split my headlights I had frickin cat hairs in one side on the lense. I should have used a quick blast of air from my compressor or a computer duster can. I will have to take it apart again this summer to correct my error.
Just my .02
Old Jan 17, 2012 | 01:13 AM
TunerMax's Avatar
G35
Just my .02
Thanks man. And yes they're all pre-lim pics, trust me, there won't be an imperfection anywhere when all is said and done, I'm ridiculously picky. Hence all this testing to get things 'just right'.
Old Jan 18, 2012 | 07:25 PM
TunerMax's Avatar
G35
Needle Illumination Testing cont.
Abandoned the inner LED ring idea for illuminating the needles more:
Going back at using the OEM prisms for this, more testing:
Plan B: Drill hole in end of Prism and insert 5mm LED:
Depth set:
Ok drill bit does'nt work, too coarse, enter Dremel:
Well, the idea was good. Turns out as soon as you touch the end of the prism, it doesn't do it's job anymore. I essentially blocked the flow of light through the prism. Oh well good thing I tried the one that doesn't matter much first
So.... I'll put a 5050 RGB chip on the end, prep/test:
Thought I'd try encasing the outer portion of the prisms, it made no real notable difference. Would work great if you wanted to make the needle colour different from the rest though, as it completely isolates the center of the gauge from the face:
Test shot and test mount ONE of 4 SMD's:
Right now it's hot glued directly to the prism. I'm going to let it sit for 12 hours and make sure nothing roasts, if it's good I'll mount the others. I took a video or two but I'm at work and can't post I'll put it up tonight.
Old Jan 19, 2012 | 12:53 AM
TunerMax's Avatar
G35
Ok, I'm surprised, but the freaking SMD wasn't even hot! Over 12 hours of constant on time, and no melting, no soft glue, can't even feel a temp difference between the SMD and surrounding area. Very, very happy. So I'm good to carry on!
Here's the links for the quick testing vids I made:
Old Jan 21, 2012 | 01:47 AM
Swivel's Avatar
Moderator
Cool stuff, Max, you are WAYYYY more ambitious than I!
Old Jan 21, 2012 | 06:23 AM
EDGAR's Avatar
Very Nice
Old Jan 21, 2012 | 11:13 AM
TunerMax's Avatar
G35
Thanks guys!
Also I just started hunting around, seems like we don't have any threads with guys who've done much on the 03/04 as far as LED conversions go? Perhaps I should include some DIY feel to this thread for others reference?
Old Jan 21, 2012 | 02:03 PM
EDGAR's Avatar
what are you planing to do with the A/C information panel display?
Old Jan 21, 2012 | 03:35 PM
TunerMax's Avatar
G35
That's a tricky one. I'm going to pop the lense off it and see what colour the LCD is. if it's white, I'll be quite happy. If that's the case I'll try and get somewhere to make a clear lense for it to replace the orange tinted one. I'll explore clear materials that would work good like fiberoptic sheets such as plexiglass, and run RGB leds all around the outside of the lense.
Old Jan 21, 2012 | 04:09 PM
EDGAR's Avatar
Behind the orange piece there is a turquoise light (lcd or led idk) panel what people usually do is use a piece of colored film and a clear piece of plexi glass or a colored plexiglass piece I did mine that way
Old Jan 21, 2012 | 04:17 PM
EDGAR's Avatar
Here is pic Name:  7fd644c5.jpg
Old Jan 21, 2012 | 04:28 PM
TunerMax's Avatar
G35
Ah nice to hear I'm on the right track cool. I have some plexi but it's way too thick I'll have to pick some up. What thickness would you recommend?
And Usually it's that light green or white, I was hoping for white, DO'H!!!
Guess I'll have to put a film on it as well as clear it out.. I'm thinking white is the best route to go anyways. I'll have to check the colour chart to see, perhaps I can just tint the lense may be easier then tinting the actual screens.
Here is pic
Nice bud that's your set up? I saw that in my hunting. Like the creativity with the different colours i'm quite sure that wasn't straightforward on our gauges. That's where the 05/06 gauges would be amazing to mod.
Old Jan 21, 2012 | 05:27 PM
EDGAR's Avatar
Try to find a 2 or 3 mm piece of plexiglas that would work great! I used a shield from an industrial mask I had laying around, and yea that's my set up right now but after seeing yours I think I am going to replace the led bulbs in the cluster, with led strips to eliminate hot spots
Old Jan 21, 2012 | 06:19 PM
TunerMax's Avatar
G35
Yeah this is the first car I've tried that with I was SHOCKED how well it turned out.
Good idea with the mask, I think I'll be stuck using something thicker though, at least the thickness of the 5050 SMD so I can have it on there perfect. OAN< how did you accomplish the different notch/number scheme anyways, any pics?
Old Jan 21, 2012 | 07:21 PM
  #30
EDGAR's Avatar
I actually do have LEDs at the end of the prisms if you noticed my neddles have a red glow on them wich is not as would want them to be since I only attached two 3mm LEDs on each of the prisms but hopefully with the 5050 LEDs I will get a better glow on them. I acomplished the different color scheme by adding a lil piece of blue film underneath
