Headlight Modding Problem/ Electrical Issue - Need Help Please
Old May 28, 2012 | 05:00 PM
JAS's Avatar
JAS
Hey - I need some help here,
I have a 2005 G35 Coupe with the stock headlights with clearance strip. I bought an LED strip to replace the single bulb at the top of the clearance strip. I had to open the headlights up (baking them in the oven and opening), and layed down the strip to fill the clearance strip with LED's the entire way down instead of just the single bulb as I said before. I also bought a cheap(ish) ($35) led angel eye (included picture at bottom) type of deal thing bottom (high beam) circle.
So after that introduction to what I've bought.. here's my problem, I have a major wiring problem now. I tried to snip the thing that holds the singular bulb going into the clearance strip at the top of the headlight and just solder the wires together from the new strip wires and the cut singular bulb. After attempting to do that, my fuse blew (the lights for the clearance light and side markers would not work now). I figured out, after some research, where to check this and sure enough it was blown.. I bought new fuses (and tried different things) and ended up having all of those 5 fuses blown. I don't know what I need to do in order for that not to happen.. it seems to be over surging and blowing the fuse, like there is too much electricity..
Any electrical advice?
(Sorry if this wasn't explained well)
Thanks,
Jordan
Attached Thumbnails Headlight Modding Problem/ Electrical Issue - Need Help Please-clearancestripsg35de5copy.jpg
Old Jun 1, 2012 | 01:09 PM
alexcaro's Avatar
Recheck your wires sounds like you have a short somewhere
Old Jun 1, 2012 | 03:27 PM
JAS's Avatar
JAS
Hey so what exactly will I be looking for?
Old Jun 1, 2012 | 05:10 PM
GZUP's Avatar
resistors?
Old Jun 1, 2012 | 05:19 PM
JAS's Avatar
JAS
Yeah I bought resistors but am not sure where to place them in the circuit. I can take some pictures tonight while im doing it and maybe that will clear it up or make something more obvious..
Old Jun 1, 2012 | 05:31 PM
GZUP's Avatar
try soldering the resistor to the neg end of the led strip and then solder back to neg end of the factory plug
Old Jun 1, 2012 | 05:36 PM
JAS's Avatar
JAS
Alright thanks, I will try that when I'm home from work.
So for the clearance strip does the original peice (the plug in spot for the bulb need to be attached because I cut that so that it was just the wires)?
And I am also trying to attach LED angel eyes, sorry to pester you with questions but this is driving me crazy, tried so many things and no dice. What do I attach those to?
Old Jun 4, 2012 | 11:06 AM
JAS's Avatar
JAS
My buddy's gf's brother works at a auto shop so im getting him a couple six packs and calling it a day.. thanks for the help - will post pics when done, should look sick
bTanz
Oct 15, 2015 02:31 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
justgotg35
Jul 19, 2015 12:33 PM
attarday
Jul 15, 2015 04:03 PM
