projector help
Old Jul 1, 2012 | 09:23 PM
kahalawhat's Avatar
projector help
i cant get a clean cutoff on my projectors this is what they look like any help would be great thank you.
Attached Thumbnails projector help-img_0037.jpg   projector help-img_0038.jpg   projector help-img_0039.jpg
Old Jul 1, 2012 | 09:46 PM
Jaygotboost's Avatar
modified? retro?
Old Jul 2, 2012 | 12:17 AM
kahalawhat's Avatar
oem 06
Old Jul 2, 2012 | 12:41 AM
Did you just upgrade to those? looks like the heat of the lights is not far enough spread out, there is a DIY for aiming your lights and that should help some, oem projectors suck and people do the TSX lense swap and modify the lense shield and get that crisp clean cut line.
Old Jul 2, 2012 | 01:48 AM
kahalawhat's Avatar
yup i recently put them on, i had them off to try and aim them, it looked pretty good off the car. what do you mean by the heat is not spread out enough? i read the how to adjust your projectors the right way thread but its kinda vague imo, it only shows one adjusting screw but if you take them off there is actually three that can be adjusted. im trying to avoid having to open them up and still get a decent cutoff. any other ideas? thanks for your help.
Old Jul 2, 2012 | 01:52 AM
kahalawhat's Avatar
its getting dark out so im gonna try adjusting it again ill post the outcome when i get back
Old Jul 2, 2012 | 02:02 AM
the heat spots are where the light looks the brightest [ focus of heat] they should be more spread apart. So instead of narrow they should be opposite of that,
Old Jul 2, 2012 | 06:30 AM
suprasam's Avatar
https://g35driver.com/forums/body-in...color-mod.html
this is what peeps are doing. this is involved but gives a great look. i did this too.
Old Jul 3, 2012 | 03:59 AM
kahalawhat's Avatar
what exactly is he drilling in the third pic?
Old Jul 3, 2012 | 04:05 AM
kahalawhat's Avatar
which way is the cut off shield suppose to face? is the cup side supposed to face foward or backwards?
Old Jul 3, 2012 | 04:08 PM
saywat?'s Avatar
yup oem projectors suck donkey ***. toyota camrys with halogen projectors have a better cut off lol. but hey projectors are better then halogen 03 lights lol
Old Jul 4, 2012 | 02:19 PM
suprasam's Avatar
The cutoff shield curves forward. If you go through with taking yours apart you will see stuff will fit one way. In the third pic he is drilling to top "lip" in the projector housing but that is not a necessary step if you are looking to even out your cutoff line.
Old Jul 5, 2012 | 06:40 PM
kahalawhat's Avatar
it looks like the guy drilled the whole thing off http://smg.photobucket.com/albums/v6...3337-K1024.jpg but in this picture it look like its still there? http://img.photobucket.com/albums/v6...Y/DSC_0700.jpg so what do you suggest? i can push the shield forward without opening it up, should i just do that? also the whole thing seems to move around a lot inside the housing idk... thanks for the help.
Picture Share
Feb 4, 2018 12:41 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
MrIP35
Oct 25, 2015 11:13 PM
alessandro
Oct 8, 2015 09:29 AM
