Interior light question
Old Mar 12, 2013 | 08:25 AM
ivey_usmc's Avatar
I have a 05 coupe I just bought and im changing out all my interior lights to led's. After I changed the map light's when the door is closed the do not turn off all the way. You can still see a faint glow of the lights. They will turn all the way off if I flip the switch from "door" to the "off" position. Does this mean I have a short somewhere?
Also
My trunk light will not come on and I know the bulbs are good. All other lights are good so far.
Old Mar 12, 2013 | 05:51 PM
saywat?'s Avatar
its normal and try turning the bulb around
Old Mar 12, 2013 | 10:58 PM
KrazySouthG35's Avatar
LEDs require such little current they stay glowing even when they're supposed to be off. You get used to it and it won't drain your battery or anything like that. And like he said flip the bulb around that's probably your issue
Old Mar 12, 2013 | 11:41 PM
saywat?'s Avatar
Incorrect. It's constantly on because the dome light uses a neg trigger so the positive side is constantly drawing power.something like that
Old Mar 12, 2013 | 11:43 PM
In what way was I incorrect?
Old Mar 12, 2013 | 11:49 PM
saywat?'s Avatar
The first sentence. Watever thats suppose to mean
Old Mar 13, 2013 | 09:55 AM
Close. In our cars even when the switch is off a small amount of current is still flowing. This current isn't enough to illuminate a standard lightbulb but it is enough to make an led bulb glow because led bulbs require much less current to illuminate. So again please explain how I was incorrect in any way?
Old Mar 16, 2013 | 12:33 AM
ivey_usmc's Avatar
Ok thanks for the advise guys. I was just worried I had a short or something.
Old Mar 16, 2013 | 09:44 AM
No problem
Old Mar 22, 2013 | 09:10 AM
ivey_usmc's Avatar
Just a up date. I turned the bulbs around and still having the same issue. I just worry about burning the led's out prematurely.
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Jadenkid22
Jul 14, 2015 12:33 AM
