Lense replacement.
Lense replacement.
I want to replace JUST the lense of the headlight since it's old and I suspect detoration.
Does after market housing lense fit well with our oem housing?
I know how to open headlight that's not a problem.
I just need to know if the lense from after market housings fit oem housing that's it.
thanks
thanks
Don't believe its been done and unlikely to fit since they are built differently . Also aftermarket lenses yellow and build oxidation faster than oem lights . May be best to source a good used set man
