Help! Riced out my G35 with wrong bulb color.
Old Jun 9, 2003 | 02:48 PM
Saridi's Avatar
Re: Help! Riced out my G35 with wrong bulb color.
I only removed 1 screw and 1 push in tab and got the work done....[img]/w3timages/icons/tongue.gif[/img]
Old Jun 9, 2003 | 06:22 PM
afr0puff's Avatar
Supa Dupa Moderator
You're joking right? If not, can you show us which one(s) you removed and how you were able to maneuver behind the fender protector?
Old Jun 9, 2003 | 10:51 PM
dennison's Avatar
I actually changed my clearance lights too, but I didn't need to go through the wheel well.
I just popped the hood, stuck my fist in the crevice between the back of the lamp unit under the hood. Then I quarter turned the clearance bulb and then there was about 6-12" of wire leeway to pop out the whole wiring harness and pop in the new 168 clearance bulbs. I didn't need to turn or remove the wheels at all. Probably took 3 minutes each bulb.
Here's a pic of my hyperwhite 168 clearance lights:
Old Jun 9, 2003 | 10:53 PM
dennison's Avatar
^ (that was my first post ever=)
Old Jun 9, 2003 | 11:24 PM
Jedi's Avatar
Dennison what brand, model #? THX
"Use the Forced Induction Luke!"
-Jedi
Ordered 4/03: 2003 G35C, 6MT, Blk/Blk. Loaded ETA ~ 6/03
Old Jun 9, 2003 | 11:52 PM
afr0puff's Avatar
Supa Dupa Moderator
Well, i finally got the nice light blue effect i was looking for. I went with the piaa BLUE/WHITE led. But i had to color in the white LED with a black permanent marker to diffuse it a little. Other wise the white was really noticeable. Now its pretty good.
Old Jun 10, 2003 | 12:00 AM
dennison's Avatar
194/168 Super White Bulb
Description: 194/168 Super White Bulb
non LED
from autodynamic.com
Old Jun 10, 2003 | 12:44 AM
Saridi's Avatar
<hr></blockquote>
Same screw as you removed I guess.....and the push in tab, I only have to remove the one vertically below the screw. Then I can just pull out those plastic and put my hand in to get the stuff done. This way I can change every bulb in the assembly except the signal light.
Old Jun 10, 2003 | 01:03 AM
dyenboy's Avatar
Registered
dang..tat looks real good..i wish they had it on the sedan...
Old Jun 10, 2003 | 01:10 AM
OvaYahead's Avatar
I know an easier way. Open the hood to the engine bay, push the wheel well down, then you can easilly reach your hand back and pop the light out to change. when your done just push the wheel well back up by the wheel side.
BS G35C 6spd navi/aero/prem
Old Jun 10, 2003 | 09:38 AM
afr0puff's Avatar
Supa Dupa Moderator
If anyone is interested in my original BLUE LED wedge bulbs, let me know. They were only on for less than 2 hours. $20 including shipping.
Old Jun 10, 2003 | 04:00 PM
pestilence's Avatar
dennison.. hi@(#$) CONGRATZ on your first post.. hehe
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
