3022 6-LED Dome: Anyone have these?
Old Sep 23, 2005 | 10:04 AM
BocaCoupe's Avatar
G's Up, Ho's Down
I was considering getting some 3022 LEDs from www.autolumination.com
Just wondering if theses are the brightest out there, if they fit and how wide the throw is.
Planning on using for dome and courtesy lights.
Attached Thumbnails 3022 6-LED Dome: Anyone have these?-31mm_sw_6led.jpg
Old Sep 23, 2005 | 11:13 AM
truplay8's Avatar
THE BATMOBILE
im happy with mine
Old Sep 23, 2005 | 11:22 AM
PeteNJ's Avatar
The output will be dimmer then stock. I wish these manufacturers used higher quality LEDs in their "plug in" arrays. The output would be much better. I wouldn't mind paying a higher price!
Old Sep 23, 2005 | 02:09 PM
Silverbolt's Avatar
Not as bright as stock... but LEDs can never have an output as much as a regular incandecent bulb. It spotlights, but the maplight cover helps spread the light out. Its dimmer that stock, but it still does the job and it looks great! I'm happy with mine.
Old Sep 23, 2005 | 02:17 PM
PeteNJ's Avatar
Silver,
That is not true. A well designed LED array can output better than stock lighting. The key is to put the LEDs outside of the lens cover. I hope to tackle this project once im done with my headlights.
Old Sep 23, 2005 | 08:56 PM
chanycrazy's Avatar
same here..!!im using blue...
Old Sep 25, 2005 | 04:28 AM
Psycraft's Avatar
yes i have those,look at my pic section those are the ones installed as my map lights
Old Sep 25, 2005 | 05:47 AM
mrjonang's Avatar
nice
Old Sep 25, 2005 | 11:05 AM
Silverbolt's Avatar
Originally Posted by PeteNJ
Silver,
Wait a sec... you're going to put the LEDs outside of the lens cover? I'm not sure I follow. Can you explain in detail?
I was looking at my brother's LED map lights last night. He has a slightly larger bulb that has 8 LEDs inside it. Theres a HUGE difference from his, and mine! I'm considering customizing the prongs in my maplight to hold a slightly larger bulb so it could hold the same kind my little brother has in his car.
parhamm1
Lighting
Mar 21, 2010 01:38 AM
chicklet
Archived Sales
Sep 18, 2006 06:44 PM
timzcat
Jul 26, 2006 02:40 AM
