Clear Corner/Clearance strip LED!
Old Oct 14, 2005 | 08:33 PM
Otacon132's Avatar
hey!, im not exactly sure, but which LED's should i be looking for? i purchased the WLED-W6....and just got themt oday, but i dont thinkt hat they are the right ones, before opening the packageing im asking here to make sure, i had been told those where it, but they just seem way to small and simply i have no idea how it goes in that socket....
first off, are both Clearance/clear corner bulbs the same? if so, which of these should i be looking to get? i want white bulbs there, but i was recommended LED's instead from Superbrightleds.com..... but anyways, which are the ones i need?
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Old Oct 25, 2005 | 10:15 PM
BlazeMaster's Avatar
I'm interested in this as well, can someone help me out? I basically just want the clear corners with the LED bulbs to replace the amber stock ones. So I just need to buy the clear corners, and a pair of LED lights that will replace the amber ones. What is the exact LED that would fit in the stock socket? Can someone shed some light please?
Old Oct 25, 2005 | 10:18 PM
jerdubois's Avatar
Please do a search on the tech section for "excel" under lights sub-directory. There is a nice spreadsheet there with exactly the info you are looking for.
Cheers!
Old Oct 25, 2005 | 10:22 PM
JohnNLuc's Avatar
I dont claim to know it all but when I had the same question All i did was do a basic search and found more than enough information on the topic the bulbs you are looking for are the 168 LED Wedge lights made by PIAA these will work both both the clearence lights as well as the corners. It's amazing what you can find if you do a little bit of searching. =]
Old Oct 26, 2005 | 02:09 PM
ipse dixit's Avatar
If you really want to fill the clearance strip with white light, you need to get the PIAA Tera LED bulbs (not just the regular PIAA LED bulbs).
The Tera LED bulbs are pricey, something like 50 bucks. You can find them on eBay, or otherwise have to buy them overseas from Japan.
Old Oct 27, 2005 | 04:05 AM
Otacon132's Avatar
sorry for not responding to my own thread, but been bombarded by the hurricane and no power, anyways, i got the LED bulbs from superbrightled, and they look sweet, ill take some pics for if people are interested on how thye looked, 5 minute install each headlight, and 10 seconds each clear corner ~
Old Oct 27, 2005 | 09:56 AM
SleekStyle's Avatar
yea man takle some pics
hey the strip uses 194 lights right??
Old Oct 28, 2005 | 01:13 AM
mrjonang's Avatar
strip, corners, trunk, licesne plate all use the same bulb - 194, 168 w/e. you can try the ones at superbrightleds.com, those are nice, there 9leds but its too blue. it doesn't match at all with my headlights.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
Gabe83714
Oct 6, 2015 06:40 AM
