D2R vs D2S for 06 projector headlamp
Old Nov 18, 2005 | 08:05 PM
GIIIV's Avatar
I just ordered my 06 headlamps from Infinitispecialist on ebay and was thinking through the install process………
I understand that we can salvage our D2R bulbs to fit the projector application by scrapping off the coating that is on the bulb. I also understand that the coating is to help reflect light or not reflect light in the reflector application.
Question is: What if we don’t scrape off the black coating before installing the D2R bulb into the projector housing? Will the coating affect the light output significantly?
Old Nov 18, 2005 | 08:31 PM
obender66's Avatar
I don't remember exactly, but I saw pics on hidforum.com a while ago(it is hidplanet.com now). D2R in projector had very minor shadows compared to D2S. Try searching hidplanet.com
Old Nov 19, 2005 | 12:48 AM
patman530's Avatar
Yes, it will affect the light output significantly. If you don't want to scrape the black coating off the D2R, just get new D2S bulbs. You will be disappointed if you use the D2R as it is since the light intensity will suffer. My 06 housings and D2S bulbs are on the way...got 2 new D2S 85122 bulbs shipped from ebay for $69.
http://hidplanet.com/forums/viewtopi...=d2r+projector
Old Nov 19, 2005 | 05:22 AM
GIIIV's Avatar
Thank you all for the feedback!
Old Nov 20, 2005 | 12:13 AM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
just take off the black and notch it it will be ds2
Old Nov 20, 2005 | 07:25 PM
waterp7's Avatar
the ceramic coating cuts down your viewable light...(decresed lumens) of output from the HID bulb. Your projectors won't be as bright as they should be. Plus the notches on the D2R bulb do not line up with the D2S openings. You'll have to cut a slit for it to fit.
Old Nov 20, 2005 | 08:02 PM
6969g35's Avatar
just shrape the black ceramic coating off
with surgical knife
and line the notch up
my friend did this with his d2r bulbs
for his projectors...no problem
My going to use same methold on 06 headlights
I have 6000k hid d2r I have make them fit..
I decided to order mccolloch 6000k ds2 bulbs
from ebay 115.00
did not want mess with the 05 bulbs
http://cgi.ebay.com/ebaymotors/ws/eB...3AAAQ%3AUS%3A1
Old Nov 21, 2005 | 03:09 AM
GIIIV's Avatar
6969g35,
Just to confirm, are you saying that you do not actually have to "cut a slit" or "notch" the bulb?
Old Nov 21, 2005 | 03:25 PM
6969g35's Avatar
Originally Posted by GIIIV
6969g35,
yes use a filing knife
Old Dec 1, 2005 | 12:23 AM
Day177017's Avatar
6969g35,
You notch the BASE of the bulb. Not the actual bulb itself.
Picture Share
Feb 4, 2018 12:41 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
twentyeggs
Sep 11, 2015 03:58 PM
JKL1031
Lights
Sep 9, 2015 01:27 AM
