Is it possible to leave the fog light on as daytime running light?
Old Dec 8, 2005 | 11:49 AM
cup0spam's Avatar
In my VW Passat, to disable the daytime running light all you needed to do was remove a relay, whch was located near the main fuse box. Perhaps this is all they do... Adding a basic relay for the CA versions but not the US would be the cheapest way for Infiniti to do it...
I bet there's a socket somewhere on this car for a relay that will enable the daytime running lights... Unless of course it can be programmed in the ECU. That'd be the cheapest way.
Old Dec 8, 2005 | 11:54 AM
chicagokid's Avatar
Originally Posted by inTgr8r
If you have the service manual, the DRL cct is in there.
do you have the website link to that?
Old Dec 8, 2005 | 02:19 PM
wilson1's Avatar
here's an idea. put a piece of tape over the light sensor and put the lights in auto. Too simple???
Old Dec 8, 2005 | 02:34 PM
Coach's Avatar
Originally Posted by wilson1
... here's an idea. put a piece of tape over the light sensor and put the lights in auto. Too simple???
Actually, it is a little too simple. That would light the HID low beams constantly - not great for the life of the bulbs. You're only using DRL's to make your car more visible to others, it doesn't need to be HID quality light. I have a Canadian '05 sedan, and my daytime running lights use the halogen high beam elements (not the fog elements) at reduced output.
Old Dec 8, 2005 | 03:00 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
sure..
Infiniti Publications
You need to sign up for a 24hr membership.
Then you can download the manual in pdf format. (many files)
It's a real deal for $19, compared to hard copy
Old Dec 8, 2005 | 03:29 PM
avs007's Avatar
My Pontiac Grand Prix is the same way. There is a fuse and a DRL relay. Pulling the fuse, deactivates DRLs, but also deactivates the auto headlights. Pulling the relay deactivates the DRL only.
However, I think this guy's question was how to wire the DRL to the switch. Because simply pulling the relay, would be illegal in Canada, and you'd be easy to spot. Maybe he just wants to be able to flip em' off, when he's at a drive in movie or something.
Old Dec 8, 2005 | 03:40 PM
Coach's Avatar
Originally Posted by avs007
... Because simply pulling the relay, would be illegal in Canada, and you'd be easy to spot. Maybe he just wants to be able to flip em' off, when he's at a drive in movie or something.
Other way around - the original poster is in California. He wants to know how to make his US model work like the Canadian one.
Old Dec 10, 2005 | 11:32 PM
ABQ_G35's Avatar
Drive-in movie? Where do you live, in Pleasantville? LOL!
Old Dec 13, 2005 | 01:29 AM
skeleton_cru's Avatar
Sedan
Originally Posted by Jtrain
Yes it is, look at your blinker fob, the inner most turning one, give it a turn-- it will turn on just fogs
WRONG!
Old Dec 13, 2005 | 11:44 AM
ratedxmarcel's Avatar
you cant just turn on your fogs...your headlights must be on before you can turn on your fogs.
Old Dec 19, 2005 | 05:29 PM
Gilley's Avatar
If I were to run DRL's, I'd want the turn signal light in the headlight assembly to function as the DRL. It's super bright and bulbs are cheaper.
Old Dec 20, 2005 | 06:28 PM
LSU072081's Avatar
so, are there any DIY could turn on the foglight w/o headlight on ?
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
cbax
Aug 17, 2015 07:41 AM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
