My Clear Corners
Old Mar 7, 2006 | 03:36 PM
  #46
MBentley's Avatar
Does anyone know where I can get the 4" white tubes? Everyone I've checked is either out of stock or don't carry them.
Old Mar 7, 2006 | 06:42 PM
  #47
ON's Avatar
ON
Originally Posted by MBentley
You could do this w/o cutting the 1/4 hole by running the wires through the hole that the bulb used right? I guess it makes hiding it a bit harder though. Great mod btw! I was looking for some alternate lighting and this seems to fit the bill. Next you should do the mod that makes the corners double as turn signals.
you could use the original hole fo rthe bulb, but i sealed it up so it would look cleaner. and yes, if you put the light in the middle, it wouldn't be hidden very well. and it doesn't look good either, IMO.
Old Mar 7, 2006 | 06:44 PM
  #48
ON's Avatar
ON
the place i got mine from is sold out, but i found this site, but it has no pictures.
http://www.hobbyengineering.com/H1962.html
This one one also has it, but is a little pricey...and i think they just give you one.
http://www.performance-pcs.com/catal...oducts_id=3128
Old Mar 8, 2006 | 10:44 AM
  #49
MBentley's Avatar
Thanks for the replies. I just found some on eBay. Paid a total of $18 including shipping for a dual 4" and a dual 12" kit. Now to get the clear corners. Thanks for the info on the mod. I can't wait to see how it looks.
Old Mar 8, 2006 | 11:43 AM
  #50
ON's Avatar
ON
good luck...can't wait to see how yours turn out.
Old Mar 8, 2006 | 02:25 PM
  #51
MBentley's Avatar
I'll definitely post some pics
Old Mar 19, 2006 | 04:34 PM
  #52
chanycrazy's Avatar
ok..i found dual ccfl kit
so im trying to put 4" or 6" in corner light and 12" in strip light with one inverter. since both light work together. and that way i don't have to get two inverter for one side.
so can i not use one of original wire? leave it unpluged...??
what do u think?
Old Mar 22, 2006 | 01:19 AM
  #53
ON's Avatar
ON
what do u think?
yea, you don't have to use both wires. Just leave one unplugged. It should be ok.
Old Apr 4, 2006 | 12:55 PM
  #54
Raheel's Avatar
How did you guys open the Sidemarker? Bake it open? I cant get it open, but I havent baked it yet, was wondering if there is another way, or if thats what everyone did?
Old Apr 8, 2006 | 01:23 PM
  #55
Sm00thRomancer's Avatar
so how long do you think the ccfl light will last? would it burn out soon?
Old Apr 8, 2006 | 03:23 PM
  #56
Raheel's Avatar
I bet a year mininmum
Old Apr 8, 2006 | 04:53 PM
  #57
codeflux's Avatar
10,000 hours minimum - so about a year at least. the problem with CCFLs is that they do burn in and fade after a while. also, the CCFL inverters tend to fry after a while.
Old Apr 8, 2006 | 06:58 PM
  #58
yungwunn911's Avatar
is it easy to actually replace the clear corner itself? you just pop it in or do you have to take the bumper off?
is there a DIY on the clear corner change? ima noob sorry.
thanks,
mike
Old Apr 8, 2006 | 08:11 PM
  #59
codeflux's Avatar
dude you just pop it off. pull on it from the side, it'll come right off. the light just twists off. 15 seconds tops.
thanks,
mike
Old Apr 8, 2006 | 08:18 PM
  #60
thanks! i dont have a G yet. but as soon as i get it i want to know everything!
-mike
