Dull Headlights! Help
Old Apr 4, 2006 | 10:31 PM
ABQ_G35's Avatar
Originally Posted by jersey-G
you don't need all that fancy stuff. Just wax the headlights and it will clean them right up. Works great.
Not really, you need to use the 3M products, they work great, and are recommended by Infiniti. It does help to keep them waxed once you get them cleaned up though.
Old Apr 4, 2006 | 10:33 PM
ABQ_G35's Avatar
Originally Posted by GeeWillikers
+1. It has kept mine looking new.
Sure, if you keep them waxed from the beginning it really does help, but you are where the sun doesn't shine like it does here, it's murder on plastics.
Old Apr 5, 2006 | 01:29 AM
Jeff92se's Avatar
Red Card Crew
Wax does nothing. It's a protectant.
Cleaner wax has very mild abrasives very similar to plastic polish.
Just to clarify. I mean really, we are talking about headlight covers.
Really?
I've used nothing BUT wax (Zymol, Mother's) on mine since I bought it new last FEB and I've never had an issue with clouding, yellowing, anything. They look as clean as they it came off the showroom.
A good cleaner wax like Zymol should work just fine.
I'm not saying the other stuff won't do the trick, merely observing that I've never needed to use anything different from what I use on the paint.
Old Apr 8, 2006 | 02:57 PM
jmonsale's Avatar
hey guys i tried the 3m rubbing compound to remove all the oxidation and fix the hairline scratches and it looked just as good as new.
Old Apr 17, 2006 | 06:37 PM
snowman's Avatar
The 3M rubbing compound works great. You can also, depending on how bad the lights look, wetsand them with 1500 or 2000 grit sandpaper...again depending on how bad they are. Then go over them with the rubbing compound and finally with a plastic polish. I got this method from my acura forum and it worked great.
Old Apr 17, 2006 | 07:03 PM
perry05G35's Avatar
Living here in Hawaii where we get rain followed by humidity I find myself using the 3m pastic cleaner about every other month. I keep a bottle handy I highly recommend you continue to use the stuff because they will get dull again. My last two cars have had xenons has anybody else noticed this problem on cars with halogens?
Old May 21, 2006 | 04:43 PM
bsoo's Avatar
WAX OR PLASTIC POLISH?
It occurs to me both might work. The wax doesnt remove the residual film, but it probably puts an even coat on the headlight cover such that all the irregularities of the surface is covered up, thus producing a smooth, clear surface. It's the same effect as when you wet the cover with water (or windex) and temporarily see a blemish-free cover, until it dries up.
So maybe it's a good idea to use plastic polish first, then wax it to protect it
My headlights have the same foggy problem, and one of them even has a crack in the reflector. I'm gonna try to see if I can get them both replaced under warranty by claiming poor workmanship....
Old Jun 2, 2006 | 04:37 AM
Oki-the-Nawa!'s Avatar
kinda late, but to me it seems like the haze is coming from the inside? am i wrong or is that the haze monster trying to fool me?
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
