Brembo Rotor and Hawk Brake Pad Questions...
Old Jan 14, 2005 | 09:44 AM
neffster's Avatar
1. Are all brembo slotted rotors gold?
2. What are the correct Hawk brake pads that are good for street driving and have low dusting? Green Stuff or something like that?
3. Where is the CHEAPEST place to get front and rear rotors and pads?
TIA...
Old Jan 14, 2005 | 11:14 AM
roadracer516's Avatar
TIA...
Be careful of Brembo "knock off's", lot's of places sell them as Brembo, but they are not! True Brembo rotors are gold, that is cadmium plating to prevent the rotor from rusting, I can tell you from experience that is wears off once you pass 12 months! If I do them, I will hi temp clear coat them before installing.
FYI" Green Stuff pads are EBC brand
I have heard really good things about the Hawk HPS pads, but do not have experience with them? I also heard that Axis Deluxe pads are good, both low dust alternative with good wear and easy on rotors.
Ebay is the cheapest! Patience is needed to find the write setup, if you lack the patience try Tire Rack, I have bought from them and like them!
Old Jan 14, 2005 | 11:35 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
TIA...
Neff, I don't know about the rotors (I'd go with stoptech 2-piece myself) but as far as the pads go, I have the Hawk HPS and they are great for both street and track...I get virtually NO dust.
Old Jan 14, 2005 | 12:39 PM
neffster's Avatar
Well, how come the stock rotors are not gold? I'm afraid that the gold rotors will look tacky behind my PIAA's with the silver finish...
Also, I thought I had to keep brembo rotors with the brembo calipers? Can't mix the stoptech hats and brembo calipers, can I?
Old Jan 14, 2005 | 01:09 PM
I think all in all the gold will look great! I have not seen your car, but I love the gold on my 330i!
Sure you can buy another brand rotor other than Brembo, just be sure they are the same specs as the stock rotor (i.e. diameter, offset, thickness), replacement rotors will always tell you whether you need to relocate the calipers, or if it is direct OE replacement.
Old Jan 14, 2005 | 01:16 PM
here are the gold rotors behind my BMW wheels, it is pretty subtle really unless your hubs are really small. You really only see the gold on the hats themselves:
File Type: bmp
Old Jan 14, 2005 | 02:15 PM
neffster's Avatar
Here's a pic of my wheel. What do you think about the gold cad plating?
Attached Thumbnails Brembo Rotor and Hawk Brake Pad Questions...-rotor-photo.jpg   Brembo Rotor and Hawk Brake Pad Questions...-rotor-photo-rear.jpg
Old Jan 14, 2005 | 02:19 PM
Brando's Avatar
Well....you already have a big ole Gold caliper....so it should look fine.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
seagrasser
May 3, 2022 09:43 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
