hey guys.. a little help here
Old Aug 8, 2015 | 08:41 PM
paolojericho11's Avatar
Hi to everyone here. I recently purchase a new set of rims 19x9.5,19x10.5 +22 offset. I was wondering if anyone from here can help me with some suggestion on which tire size i'll get for my coupe. also im lowered on tanabe df210 springs. also I'm thinking of getting a camber kit for fronts and rears and also wheel spacers.I wanna make it look flushed any suggestion on everything that can help me are welcomed and I appreciate it a lot thanks in advance...
Old Aug 8, 2015 | 08:54 PM
Albanian122's Avatar
I'm currently running
275/35R-19 in the Rear with 26mm Offset
245/40R in the front
With work VSXX Step lip, the car is sitting on KW Variant 2's and i love the way the car's stance is but I want to run 10mm spacers soon. Hope that helps
DOMO
Old Aug 8, 2015 | 09:01 PM
thanks..Right now my set up is 20x8.5 all around +13 offset fronts are 245 35 20 rears are 255 35 20 and I have a big rubbing issue on my fronts because the left side rubs on the s
Old Aug 8, 2015 | 09:16 PM
This is how the car is sitting on a mild drop I do want the tires and fenders to be more aligned and flush I will put the spacers on and might roll the fenders
Old Aug 8, 2015 | 10:14 PM
thanks albanian 122 mine as of now is slammed is that the lowest setting on your coils
Old Aug 8, 2015 | 10:27 PM
No it's the first setting I just installed them less then a month ago letting them break in for the first few hundred miles I'll most likely need to roll the fenders to avoid rubbing just search the forums and check out other members who are slammed I saw a thread full of wheel fitment
Old Aug 8, 2015 | 10:28 PM
https://g35driver.com/forums/wheels-...pecs-only.html
Old Aug 8, 2015 | 11:50 PM
Urbanengineer's Avatar
Thot your coupe is white???
Old Aug 11, 2015 | 07:59 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We'd run a 245/35-19 and 285/35-19.
Old Aug 11, 2015 | 10:58 PM
245/35/20 is what i have right now on my fronts and my fronts rub whenever i make a full turn. it had destroyed my splashguard. right now the car is slammed at 245/35f,255/35r at 20x8.5 all around
Old Sep 10, 2015 | 11:54 PM
Paul Barragan's Avatar
Hi guys I'm also new here. I have a 2007 g35s sedan. Any of you have TEIN S Tech lowering Springs? And if so, how does your ride look/feel?
Old Sep 11, 2015 | 07:08 AM
VenomGT9's Avatar
Straight savage highjacking
wuzz-upp
Oct 3, 2015 04:21 PM
g35coupe2
Sep 17, 2015 04:00 AM
Jyounya
Sep 12, 2015 04:03 PM
gatorglaze
Sep 10, 2015 12:03 PM
