David's 2007 G35 Coupe Build Thread
Old Sep 25, 2015 | 07:49 PM
davizzle's Avatar
Hello Everyone,
I've been off and on the G35Driver forum but havent been posting or sharing so I decided to change that.
I bought a 2007 Infiniti G35 Coupe in October 2013, modded it and took it to local shows in WA throughout 2014.
2015 has been more mellow and I've brought it back to a more daily-driven look.
I've found some time and decided to post up my G35 and where I've gone with it over my time of owning it.
I will be continually updating pictures as I find free time to do so.
Follow me on Instagram: @davidfishchuk
Subscribe to me on Youtube: David Fishchuk
Here is one of my favorite pics when my G35 was in its prime in summer 2014:
Here is a video made of my G35:
Sound clip of my Muffler-Delete exhaust
Modification List:
Exterior:
Nismo Front Bumper (Custom gloss black grill inlets)
Spec-D Black Gloss Grill
Custom WRX STI V-LIP
Carbon Fiber Window Visor
Carbon Fiber Rear Diffuser
Clear Corner Bumper Lights
Side Skirt Splitters
Custom painted projector Black Housing Headlights
Suspension/Wheels:
BC BR Coilovers
STR 601 20x9/10.5 +30/+35 (offset with spacers is -2/+3)
32mm spacers all the way around
Nankang NS20 225/35-20 Front Tires
Nankang NS20 255/35-20 Rear Tires
Blue Godpseed Lugnuts
Godpseed Front Camber
SPC Rear Camber
Powerstop Drill/Slotted Rotors
PosiQuiet Brake Pads
Engine Bay:
JWC Pop Charger Intake Filter w/ Heat Shield
Stillen Ztube Intake tube
Carbon Fiber Engine Cover
Carbon Fiber NRG Hood Dampers
JDM Brake cover
Custom Blue NRG Strut Bar
Interior:
VIP Bubble shift ****
VIP pillows
VIP white Fusa and Silver Tsuna knot
custom polka dot inserts/boot from local craft store
JDM Double Din Dash Kit for OEM Navigation
JVC Double Din Unit
12" JL 12W0V2-4 300W Subwoofer
Custom Zenclosure Subwoofer Box
Alpine MRX-M110 AMP
Now.... without further a-due, here is what I started off with back in Ocotober 2013:
Big 'ol "baller" EXE Konvex on stock suspension, peeling carbon fiber roof wrap, broken CD player, badly chipped and painted Nismo bumper, screwed up side skirt due to a jack slipping, bad brakes, random stickers and an exterior that needed to be clay bared badly since it sat under a tree for a few months.
Luckily, the interior was swapped from tan to black and had navigation!
Here is day one after a quick wash:
The first thing I did was get to work with the exterior. I removed the stickers, Carbon Fiber roof wrap clay bared, buffed out scratches and waxed the car.
I used Meguiar's Clay Bar Kit , 3m Rubbing Compound, Meguiar's polish, then finished with Meguiar's Gold Wax.
Next I debadged the trunk using a heat gun and goo gone
Then removed the tail light tint using brake cleaner and then plast-x to polish them back up.
Soon after I found a good deal on Tein S-tech springs, plasti-dipped the front grill and had myself a mini-photo shoot.
After a few months I saved up for a JVC KW-V200BT Double Din, JDM Dash Kit and installed a 12" JL 12W0V2-4 300W Subwoofer with a Alpine MRX-M110 Amp put into a Custom Zenclosure Subwoofer Box.
Next I plasti-dipped the front grill, bumper grill inlets, purchased the perfect gloss black mesh grill (Previous was a dull silver color), and added an ez-front lip.
I finally got my first set of wheels: STR 601 20x9 +30, 20x10.5 +35 with Nankang NS-20 225/35R20 Front, Nankang NS-20 255/35R20 Rear. (Still lowered on G35 Tein S-Tech Springs).
At this point I got tired of seeing the wheels so sunken in, so I purchased wheel spacers! The front I put 15mm spacers and the rear I put 25mm spacers.
I also added a carbon fiber rear diffuser.
Old Sep 25, 2015 | 07:50 PM
davizzle's Avatar
I finally got a set of BC BR Coilovers and added Godspeed front camber arms and SPC rear camber.
Since my brakes were obnoxious and squeeking constantly, I decided to get PowerStop Drilled/Slotted Rotors with Posi-Quiet Brake Pads. At the same time I painted the brakes red with Dupli-Color paint and got Red Muteki Lug Nuts with Locks.
I also purchased a Carbon Fiber Rear Window Visor as well.
Here are some pictures from a local Nissan/Infiniti car event:
Then I found a great deal to re-paint my front bumper and side skirts.
I got the bumper inlets and grill painted a gloss black instead of a plasti-dip black.
At the same time, I had a friend help me plasti-dip my wheels white. We used 4 cans of white plasti-dip and 3 cans of Pearlizer to match the Pearl of the G35 paint.
As well, I purchased a V-Lip from a Subaru WRX and drilled it into the bumper for a custom styled splitter.
I also went from 15mm front spacers, 25mm rear spacers, and added 32mm spacers all the way around. I bought a fender roller kit to pull and roll all the way around.
My wheel offset after was 20x9-2 Front, 20x10.5+3 Rear.
Up next was some engine dress up.
Started with NRG Carbon Fiber Hood Dampers
Then a Carbon Fiber Engine Cover
Added on a JWT Pop Charger Intake w/ Still Z-Tube, JDM Brake Fluid Cover and a Polished NRG Strut Bar
Here some pictures at a local drift event/show
Then I decided to start adding interior pieces
Junction Produce Replica Neck Pillows, VIP white Fusa and Silver Tsuna knot, Custom Polka Dot Shift Boot, Door Inserts, Arm Rest and a VIP Bubble Shift ****. At the same time I went into the Trunk and added more Polka Dot material!
My wheels started bugging me at this point. The rim lip was half black, so I decided to sand them dude using 400, 800, 1000 sandpaper and polishing them with Mothers Mag/Aluminum Polish.
Now I could see even more rim poke
Old Sep 25, 2015 | 07:53 PM
davizzle's Avatar
Here are some additional photos of my car at this stage.
I also added side skirt splitters as you can see below!
Next step, Black Housing Headlights I also made my own custom headlight eye lids using 1 can of white plasti dip and 1 can of pearlizer plasti dip.
Additionally I installed a set of side-skirt splitters and removed my side skirt mud guards.
I also got invited to be on the top floor for the TOP 100 Stance Wars yearly event
Right after the show I got tired of my wheels being plasti-dipped white, so I peeled it off. I also decided to paint my brakes calipers blue, get blue Godspeed Lugnuts and paint various engine bay pieces either black or blue
A friend of mine also did a mini photo shoot
And Another:
From Hot Import Nights Seattle. I took home 2nd best Infiniti
davizzle's Avatar
Awesome shoot done by a friend of mine locally:
I also got a Spec-D Black Badgeless Grill as well and did another shoot:
As well, I did the same with my headlight eye-lids so I peeled them off also
I decided to take out my own camera and do a shoot on a foggy morning
Night photoshoot taken by a friend:
Last show with my setup
Then I decided to move on with my STR 601 wheels and go with OEM G35 wheels for a little while
File Type: jpg
Old Sep 25, 2015 | 07:54 PM
davizzle's Avatar
I sold my BC BR Coilovers and went back on my Tein S-Tech Springs so I can drive my car more comfortably, since kissing the pavement wasn't always fun..
But then I changed my mind yet again and bought Megan Coilovers and got Varrstoen ES 19x9.5 + 12 19x10.5 +12 wheels with Achilles ATR Sport 2 245/35R19, 275/35R19 Achilles ATR Sport 2 tires
I decided to once again put the car on Tein Stech Springs so I wouldnt have to deal with speedbumps and driveways and now I'm on G37 rims with 225/40R19 Delinte Thunder D7 Tires Front, 245/40R19 Delinte Thunder D7 Tires rear. I also put on 15mm spacers up front and 25mm spacers in the rear
Now, after 6+ months driving like that, I decided to put another set of STR 601 wheels with the same specs, but with wider tires, eg. 245/35R20 Delinte Thunder D7 Front, 285/30R20 Delinte Thunder D7 Rear and keep my ride height.. but of course that can change.
I will keep you guys updated on that when the wheels are mounted!
Old Sep 25, 2015 | 09:52 PM
ThatOneDude's Avatar
Hi Fishchuck
This is David Le haha
Old Sep 25, 2015 | 11:55 PM
Mr. Brooks's Avatar
Where's the rest
Old Sep 26, 2015 | 12:55 AM
davizzle's Avatar
Originally Posted by ThatOneDude
Hi Fishchuck
Your G looked so sick in the parking lot at Drift Con by the way
Old Sep 26, 2015 | 12:56 AM
davizzle's Avatar
Originally Posted by Mr. Brooks
Where's the rest
I'm going to progressively post them when I have some free time
Old Sep 26, 2015 | 11:01 AM
VenomGT9's Avatar
Damn, I guess we will never find out what the mission was
Old Sep 28, 2015 | 02:22 PM
davizzle's Avatar
Originally it was to take my car to shows as a "daily driven", mild build. But after the first summer showing I decided to stop showing and have a more comfortable drive to my car.
Old Sep 29, 2015 | 01:26 PM
davizzle's Avatar
Updated
Old Oct 1, 2015 | 09:35 AM
Frankieg35's Avatar
Didn't you get a G37??
Old Oct 1, 2015 | 12:18 PM
davizzle's Avatar
I still have it, but I'm trying to sell it
Old Oct 6, 2015 | 02:33 AM
Frankieg35's Avatar
How come?? Like the 35 better??
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
