axis mod 7's on 350z s-tech's
Jan 4, 2009 | 12:33 PM
Bought these used a couple weeks ago. I had to get spacers for the front before I could install them, I'm going to put spacers on the rear also just don't have them yet.
Anyway they are 20x9f and 20x10r with bigger tires than I really wanted....245/35 and 275/35. I will probably try to run some 235/30's and 265 or 255 30's before long because these rub in the front when going over dips in the road
http://i552.photobucket.com/albums/j.../shandi038.jpg
http://i552.photobucket.com/albums/j.../shandi037.jpg
http://i552.photobucket.com/albums/j.../shandi028.jpg
on a side note, how do you post pictures on here without a link? I would like them to just show up on the page but don't know how to do that.
Reply 0
Jan 4, 2009 | 02:28 PM
NICE!!! i just picked up a use set of 20s also LOL!! for dirt cheap..i couldnt pass em up...
NICE COLOR! is that a custom paint? never seen that color before for the 1st gen.
Good looking car
Reply 0
Jan 4, 2009 | 03:00 PM
yeah, I got mine cheap as hell to lol
It's the new titanium color that comes on the gtr's, I just painted it a couple month's ago.
Thanks!
Reply 0
Jan 4, 2009 | 05:21 PM
rubbing due to spacers? rubbing on the fender or the plastic part inside?
how about the rears?
i like the drop of the car...
Reply 0
Jan 4, 2009 | 06:25 PM
Nice, do you have spacers in the rear? I think it would look good if the rear wheels stuck out just a tad more
Reply 0
Jan 4, 2009 | 07:09 PM
Quote: rubbing due to spacers? rubbing on the fender or the plastic part inside?
yeah, I had to get spacers to clear my brakes but that set the wheels out so far that they rub sometimes. It's just on the inner plastic liner, not the fender itself. I am too scared to go fast around sharp corners that have dips, that would probably cause it to hit the fender lip
These offset suck a** for sure on a coupe with brembo's but they were cheap and will work until I can get something better. I might end up running these in the winter once I get volks.
Reply 0
Jan 4, 2009 | 07:11 PM
Quote: Nice, do you have spacers in the rear? I think it would look good if the rear wheels stuck out just a tad more
lol not yet, I'm getting some though. I just ordered them for the front first to make sure the wheels were even going to fit. I plan on using a 15 or 20mm spacer in the rear to make it look like the front.
Reply 0
Jan 5, 2009 | 12:16 PM
how cheap is cheap?
Reply 0
Jan 6, 2009 | 10:52 AM
what front bumper is that...it looks hot
Reply 0
Jan 6, 2009 | 01:22 PM
top secret replica
Reply 0
Jan 6, 2009 | 02:55 PM
hey larry, what lugs did u use for those? the spline or reg tuners dont work with the caps...i found out the hard way, after i slapped them on!!
im trying to find those short little ones with the star pattern? i dont wanna get gorillaz or McGard ones and find out they dont fit..
whats ur suspension?
thanks
Reply 0
Jan 6, 2009 | 06:19 PM
Quote: hey larry, what lugs did u use for those? the spline or reg tuners dont work with the caps...i found out the hard way, after i slapped them on!!
thanks
There just little open end lug nuts they came with my wheels since I bought them used. I think you could get them at any tire/wheel shop pretty cheap.
tein s-tech's for a 350Z
Reply 0
Jan 6, 2009 | 08:00 PM
thanks bro, thats what i figured bout the lugs.ill check with a shop.
good drop, no gap...def. going stechs with the 20s,
Reply 0
Nov 11, 2013 | 11:17 PM
what size spacer did you add to the front? I just got myself a pair of these and I got a 04 with brembos
Reply 0
