Progress Thread: DarksideG35
Old Sep 6, 2012 | 04:59 PM
  #391
Big Booty Trudy's Avatar
Originally Posted by darksideG35
well i went out to test fit the meisters on the car earlier today and unfortunately with a 10mm spacer on the front they still will not clear the akebonos and i dont want to run anything bigger than a 10mm so needless to say i will probably be cleaning and polishing them up and then posting them up for sale soon. in the mean time heres a test fit pic
Nooooo. That would have looked sick!
Old Sep 6, 2012 | 05:02 PM
  #392
Drew113's Avatar
Ban Hammer Expert
so you didn't check the specs before you bought em to make sure they'd work??
Old Sep 6, 2012 | 05:05 PM
  #393
Frankieg35's Avatar
What size spacer do u need?? Those look sick with the yellow calipers and huge rotors..
Old Sep 6, 2012 | 05:22 PM
  #394
JaE35's Avatar
Moderator
G35 Sedan
i think the look is worth a 15mm spacer...seriously lol, it's beautiful
Old Sep 6, 2012 | 05:25 PM
  #395
Frankieg35's Avatar
Oh hell yeah!!
Old Sep 6, 2012 | 05:28 PM
  #396
jookyshank's Avatar
I haz hugz to givez
What are the specs again?! so sick
Old Sep 6, 2012 | 05:39 PM
  #397
D_Rek's Avatar
Wow, just simply wow.
Old Sep 6, 2012 | 05:47 PM
  #398
darksideG35's Avatar
thanks man, guess ill find a way to make it work
i was told on myg37.com that you only needed a 10mm spacer to clear the front brakes but that wasnt true apparently. the rears clear fine without the spacer but i wanted to push them out to match the fronts
i did, those were the ones i was talking to you about over in the wheel/tire questions thread
theyre 19x9.5/10.5 +23/24 so after the 10mm spacers theyre +13/14. i knew they would be close and i read on myg37 that you only needed a 10mm spacer to clear the akebonos up front but unfortunately its not close. so i guess ill be buying a 15mm for the front and hope that it clears the brakes and the fender
thanks
Old Sep 6, 2012 | 05:49 PM
  #399
Drew113's Avatar
Ban Hammer Expert
what are the disks front and rear?
  #400
Frankieg35's Avatar
That's for the g37, doesn't the bracket to make the bonos fit the g35 push them out further??
Old Sep 6, 2012 | 06:01 PM
  #401
not sure, the previous owner didnt really take care of them and never cleaned the backs of the wheels so the stickers are gone
true, guess i didnt think about the stupid bracket making it that much closer they were very close to clearing with the 10mm spacer on but just barely caught the bottom corner of the akebono caliper so hopefully with the 15mm it will be enough to clear
Old Sep 6, 2012 | 06:12 PM
  #402
Frankieg35's Avatar
Make sure u have at least a couple millimeter of clearance..
Old Sep 6, 2012 | 06:14 PM
  #403
oh i know, i need atleast 2-3mm of clearance to be safe. and i just cleaned off the inner lip of the rear wheels and theyre O disc, the fronts are more than likely R disc
Old Sep 6, 2012 | 06:15 PM
  #404
Drew113's Avatar
Ban Hammer Expert
if the fronts were r-disc you would be able to fit them....those aren't really aggressive offsets and i'm having a hard time figuring out whey they aren't fitting
Old Sep 6, 2012 | 06:17 PM
  #405
Frankieg35's Avatar
R-disk usually clear big brakes.. I guess the bono calipers run wide..
