Custom Modified '05/'06 OEM 19s
Old Nov 30, 2005 | 03:02 PM
G35UKY's Avatar
Lightbulb Custom Modified '05/'06 OEM 19s
Does anyone know if it would be possible to have the '05/'06 OEM 19s modifed to have larger "lips" ? I was thinking there might be a way to cut the center out and weld it to a wider "dish" so that you could go from FR 225/40-19 and RR 245/40-19 to FR 265/30-19 and RR 285/40-19.
I really like the OEM wheels but just wish they had more lip and were wider to fill in the fender wells better.
Let me know if you know of anyone I can ask about this.
Old Nov 30, 2005 | 03:30 PM
sen_jen's Avatar
Meatshake Enterprise
this is impossible imo. you'll take away the integrity and strength this forged wheel has. it would be nice though. you might be able to find a similar styled wheel with labia's through another manufacturer though.
look into:
Work
Rays (oem manufacturer)
Racing Hart (not RH Pro; Dazz)
Old Nov 30, 2005 | 03:37 PM
jdbinspired's Avatar
I 've seen some aftermarket wheels out there that look almost similar to the OEM 19's... just with more lip...
Old Nov 30, 2005 | 03:42 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You're kidding.. right
No Fn way
Old Nov 30, 2005 | 03:50 PM
G35UKY's Avatar
No Fn way
Oh, there's always a way! The OEM is at least a two piece wheel, right? I'll see if I can find anything out from Rays. Does anyone know the part numbers for the FR and RR wheels off hand?
Old Nov 30, 2005 | 03:51 PM
sen_jen's Avatar
IMPOSSIBLE. the oem wheels are 1pc. forged.
Old Nov 30, 2005 | 03:55 PM
MikeyMike's Avatar
Rollin On Dubz
Doesn't Volk make a rim very similar looking? I think the GT-C?
Old Nov 30, 2005 | 04:02 PM
sen_jen's Avatar
actually, the GT-C's (1st one in 2nd row), are not split 5's. i think there aint anything from Volk's that are similar though.
Attached Thumbnails Custom Modified '05/'06 OEM 19s-volksema1.jpg
Old Nov 30, 2005 | 04:44 PM
G35UKY's Avatar
It has to be at least 2 piece doesn't it? I don't see how they could forge these wheels as one piece, but it could very well be.
Old Nov 30, 2005 | 04:54 PM
sen_jen's Avatar
nope, they're 1pc. like the TE37/LE37's, CE28/LE28's, and the Progressive's.
if it was multi piece, it would cost hella much $$$ because of the pad design on the OEM's. it won't be able to just bolt/weld up to any barrel width. only specific one's that are Tested by Ray's.
still, Impossible. if there was a company that does this, they would fold for good.
Ray's (Volk Racing 1pc. forged models):
The Volk Racing TE37 by RAYS Engineering is the current line of street and race wheels in various versions. The main line TE37 is the forged aluminum version.
Material is 6061 aircraft grade aluminum. This material is hot forged. 1st forging process is done with pressure of 5,000 kilograms per square centimeter. 2nd forging process is a slow process with 3,500 kilograms per square centimeter.
The lip is also forged to 3,500 kilograms per square centimeter. This allows the wheel to have less material than other wheels, but have more strength and durability.
The wheel's excess material is machined off (to tolerance of 1/100 of a millimeter). Powder coating and clear coating is done by a special proprietary process to ensure long lasting quality and durability.
The weight of Volk Racing TE37 is 8 lbs. for 15 x 6.5 and 16 lbs. for 18 x 8.5. With this kind of lightness and durability, it is no surprise to see that this wheel is a very coveted wheel among enthusiasts.
check this out:
http://www.jrponline.com/downloads/mm/rays.wmv
Old Nov 30, 2005 | 05:12 PM
G35UKY's Avatar
check this out:
SenJen, thanks for the information! I guess that pretty much shoots down my idea. I wish they were 2 piece.
Old Nov 30, 2005 | 05:17 PM
ScottR's Avatar
I wouldn't try it. Like others have said there are similar wheels on the market, The PIIA Super Rozza or the Work Meister S2R are my personal favorites. I too would like a wider, say 9.5 rear on the OEM 19's but not enough to kill the strength and integrity of a very nice forged wheel. Not to mention myself Just my .2
Old Nov 30, 2005 | 05:54 PM
G35UKY's Avatar
Great suggestions, ScottR! I want to keep the look of the OEM wheel but want wider tires with more wheel lip, and these wheels will certainly accomplish that!
Old Nov 30, 2005 | 05:57 PM
truplay8's Avatar
THE BATMOBILE
def not possible............better off going with after market......and you have a MUCH wider variety
Old Nov 30, 2005 | 06:00 PM
sen_jen's Avatar
the S2R's don't come in 19's though. 18's are max. the PIAA Super Rozza's come in either 19's, or 20's. plus, the labia is now stainless.
