Spacers Installed on Wheels
Old Jul 22, 2008 | 07:26 AM
bowzer's Avatar
Got a set of 15mm ichiba hub centric spacers. The quality of them is great and a snap to install since the studs are pressed into the spacer. Here are the pics on just the one side. I will now have to order another set as I think 15mm will be perfect on all 4 corners.
I'm dropped on 350z h&r sport springs, the rims are 18x8 40mm offset (now a 25mm) and the tires are 245/40/18.
Before Front
After Front
Before Rear
After Rear
Old Jul 22, 2008 | 09:09 AM
LightsOut's Avatar
SIETESG
yeah that looks good. some might say put 20mm but 15 looks good.
Old Jul 22, 2008 | 09:37 AM
FlyingLumpia's Avatar
Looks good, how about a shot of the whole side of the car
Old Jul 22, 2008 | 11:13 AM
NorthSideRacing's Avatar
Looks alot better
Old Jul 22, 2008 | 11:48 AM
gtrefever's Avatar
your offset is 25 all around now? doesnt look as aggressive as i thought it would be
Old Jul 22, 2008 | 01:30 PM
maliy06's Avatar
looks nice, a lot better, i think i will go the same way,
Old Jul 22, 2008 | 01:33 PM
Da_ReD_G's Avatar
Looks very nice!
Old Jul 22, 2008 | 01:41 PM
Da_ReD_G's Avatar
got 25mm on my coupe and to be honest its still has finger space between fender and tire. Plan on getting maybe 15mm or 20mm in front. Looks sharp man....i like..
Old Jul 22, 2008 | 01:43 PM
nghiars's Avatar
does the passenger side rear wheel looks a bit more flushed than the rear driver side?
Old Jul 22, 2008 | 01:57 PM
G35Papa's Avatar
Spacers FTW!
Spacers even make stockers look much better. Hella Flush!
Old Jul 22, 2008 | 04:04 PM
maliy06's Avatar
thats the before and after pictures,
Old Jul 22, 2008 | 05:41 PM
gtrefever's Avatar
can you take a picture from the front of the car i wanna see how much the wheels are tucked under or if any.
Old Jul 22, 2008 | 07:32 PM
That is because its a 18x8, if it was a 18x8.5 it would look more aggressive.
Old Jul 22, 2008 | 07:35 PM
bowzer's Avatar
I will try to get some more pics up tomorrow, the damn battery crapped on the camera.
As of right now I only have them installed on the passenger side, I have ordered the other set though, so next week it should be here and put on.
I wanted to see how much I could do, I could prolly get away with 20mm, but didn't want it to be too aggressive.
Right now the rears aren't rolled, if they need to be done, then they will get rolled.
It's 25 offset now, but you've got to also remember that's not on the typical 8.5 front fitment or 9.5 rear fitment, it's on an 8 fitment.
Thanks for the comments.
Old Jul 22, 2008 | 07:37 PM
bowzer's Avatar
FlyingLumpia
^^^^Exactly what I said, even though it looks like I could go with 20mm in the rear and be fine.
