Half way there...
Old Aug 10, 2009 | 02:34 AM
azzkikr's Avatar
dam that's alot of money for turbo. But then i see your from the Hills so i guess it's just pocket change. But dam definately looking forward to the final show, good luck with everything.
Old Aug 10, 2009 | 02:47 AM
Nickk6's Avatar
Heh, thats definitely not pocket change. Its called hard work, otherwise I would have been able to pay someone to do this. But thanks anyway.
Old Aug 10, 2009 | 02:48 AM
Nickk6's Avatar
Originally Posted by MightyG35
wire tuck while your there. coming along nice!!
A little late for that, is there a DIY thread? Always wondered how that thick loom of wires would be able to get hidden...
Old Aug 10, 2009 | 03:17 AM
CandlestickPark's Avatar
ill Sedan
Sickness Nick! Good luck with the rest of the install!
PM sent
Old Aug 10, 2009 | 03:36 AM
j 4 lD's Avatar
Moar pics please
Old Aug 10, 2009 | 11:21 AM
tampagsedan's Avatar
So sick! Props on doin on the work yourself.
Old Aug 11, 2009 | 09:56 PM
Nickk6's Avatar
Here is the last bit of mods going into the car. I am just waiting on my HKS Camp2 and all harnesses. The last thing I should need is just the device to connect the Camp2 to the OEM navigation.
Cosworth Intake Manifold - I didn't want it polished.... but I also didn't feel like waiting for a none polished one.
CJM twin Walbro 255lph pump
Tial Wastegate and Mishimoto Fan
I need to pull the transmission unfortunately, just another one of those snags, but won't delay anything really.
Replacing the clutch pivot ball with a heavier duty version and new ss clutch line
Fitment issues to work out for both sides of the intercooler brackets
Revised intake turbo piping, G35 specific. The 350z pipes actually fit much better, I might use them if I can't get these in nicely.
Passenger side on top, driver side on bottom
Vs old piping (those tabs on the old pipe line up better than on the new piping, but its not pictured)
These new pipes actually make the filter face inward instead of outward. However a quick test fit tonight made me think I wont be using either of these.
Old Aug 11, 2009 | 10:10 PM
ill Sedan
Very nice Nick. How could you say that you didn't want that Cosworth polished...that's blasphemy, haha.
Old Nov 14, 2009 | 02:35 PM
The Stimulation's Avatar
Any updates Nick?
Old Nov 14, 2009 | 03:34 PM
Andrei's Avatar
Props for doing all the work yourself. I like to see more 05-06s that are turbo. Any issues having enough room with the CJM fuel system. Does it all fit?
What exhaust setup are you running?
Are you upgrading the rear axles?
Have you thought about having the intakes for the turbos behind the grill like Tims sedan? It's the best configuration.
Is the HKS ems locked?
This coolant hose running across the timing cover can be eliminated to make the car run cooler. Check https://g35driver.com/forums/engine-...coolant+bypass
Old Nov 14, 2009 | 03:38 PM
Andrei's Avatar
PM sent
Post link to wire tuck please.
Old Nov 14, 2009 | 03:46 PM
Once I got a full time job going i'll be going with a GTM TT kit Hopefully that will be sometime next year. Gonna do some motor upgrades and a valve body upgrade as well. If not next year, hopefully the following, and by that time, might even have a built motor.
Old Nov 14, 2009 | 03:50 PM
Andrei's Avatar
This ****ing recession is kicking most peoples *** right now. GL though.
Old Nov 14, 2009 | 04:01 PM
Yep. I work for the city so I've been part time for a while after my internship ended. Going full time is impossible unless it's really needed.
Old Nov 14, 2009 | 07:00 PM
  #30
GeeRider's Avatar
looks sick
