OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Dec 20, 2010 | 08:38 PM
  #2641
4DGS's Avatar
Exactly what I was going to talk to you about later. 225 is barely a stretch and 215 is too small.
To tuck tire on a 215/35 your fender needs to be about 23" from the ground.
I had about an inch from bumper to ground when I first mounted my weds because I wanted to be dumped, hence why I had to bring the car up!
Old Dec 20, 2010 | 08:43 PM
  #2642
SN00P's Avatar
CLUB MODERATOR
so i guess pretty much 19s suck with a 8.5 front lol
Old Dec 20, 2010 | 08:45 PM
  #2643
CandlestickPark's Avatar
ill Sedan
Well they don't suck, I pulled it off. I just don't have as much stretch as I would like on my fronts. 9" and wider is preferable for sure.
Old Dec 20, 2010 | 08:51 PM
  #2644
SN00P's Avatar
CLUB MODERATOR
as low as you are Marcus is there any reason you didn't go with a 215/35 in the front ?? can someone find me a picture with a 215/35 on the front of a car so i can just see ... Marcus are you hella flush or a little poke in the front with your 8.5 225/35 ?
Old Dec 20, 2010 | 08:52 PM
  #2645
4DGS's Avatar
Because he wouldn't tuck on 215s
You should buy a another pair of your rears (like $400?) and then keep the fronts as spares.
Old Dec 20, 2010 | 08:54 PM
  #2646
SN00P's Avatar
CLUB MODERATOR
and what rock front and rears 9.5 lol i already have a spare front .. i have a 19x8.5 +35 sitting in my garage .. i dont need anymore of my wheels laying around lmao
Old Dec 20, 2010 | 08:55 PM
  #2647
4DGS's Avatar
Yea run 9.5 square
Sell your fronts!
Old Dec 20, 2010 | 08:58 PM
  #2648
ill Sedan
Of course I'm hella flush in the front, haha. Just kidding, I'd have a tiny bit more poke if my wheels were wider and I had more stretch, but its definitely flush up front. The stretch is more than what this pic shows, but its not a ton of stretch by any means.
Old Dec 20, 2010 | 09:00 PM
  #2649
SN00P's Avatar
CLUB MODERATOR
im trying to find the best way to stance what i have now so i can use the money towards the volks i want and get my BBK .. lets make something happen lol what would be an ideal goal with 8.5 and 9.5 on my car and be around -2.5º to -3º ... only crappy part is my front offsets are 40's !!! i would run a 38mm spacer but i don't know who the hells wants to really do that lol and for the rears i can make something happen and get it to +10-
or +15 thats fine
Old Dec 20, 2010 | 09:18 PM
  #2650
ill Sedan
If you don't want to run huge spacers then just do a setup similar to Tyco RC's current setup. He's running 235/245 on his 8.5 +20 /9.5 +20. I'd go to +15 on the fronts, pretty sure RC was running a spacer to bring his to +15.
Old Dec 20, 2010 | 09:25 PM
  #2651
SN00P's Avatar
CLUB MODERATOR
i may just do something similar to your set up Marcus .. i want smaller tires then that that way i can always had bigger spacers if i change my mind later ... the biggest spacer id run is a 30mm i guess and the rear a 20mm so i would be at +10 front and +15 rear .. it that doable with a 225/35 and 235/35 ? cause im going to start ordering spacers this week :-)
Old Dec 20, 2010 | 09:27 PM
  #2652
ill Sedan
Yeah that's doable on a 225/235 setup. You are going to have to do some fender work though for the amount of camber you want to run. What brand tires are you going with? You want to get something that runs true (vs ones that run big and won't stretch as much). Are you going to lower it more too?
Old Dec 20, 2010 | 09:38 PM
  #2653
SN00P's Avatar
CLUB MODERATOR
well i was looking at the general tires and can get a good deal on them but im leaning towards falkens but heard they are not to good for stretching ... with a 235/35 on a 9.5, whats the least offset i can do without fender work and keeping it at or between 2.5º to 3º
Old Dec 24, 2010 | 01:36 PM
  #2654
compuvision02's Avatar
Some sexy *** G's in here...!
Old Dec 24, 2010 | 04:23 PM
  #2655
4DGS's Avatar
You really need to get your fenders figured out to be honest.
2.5-3 and you'll be able to do +20 no problem.
I did +17 9.5 with a mild roll and 225/35 and still had room to move.
You just need to be careful since your fenders are cut they have an even sharper edge on them. Increasing the likeliness to cut through the sidewall in one slice. And in the stretched tire world, blow outs are the end of your car for a little while.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
