OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jul 2, 2011 | 05:08 PM
  #4051
forweareLegion's Avatar
Looks fantasmic iiiiiekoiiiii.
Originally Posted by 4DGS
Outside of my fenders now are starting to look pretty beat lol I just keep touching them up. I'll spray the whole car then they start looking like ****.
Haha yeah i feel your pain. Happened with my old toyota, ended up changing the color of the car ha.
Old Jul 2, 2011 | 05:09 PM
  #4052
The Stimulation's Avatar
Y'all know nothin bout rubbing on the inside...
I hated when my fenders would buckle too (fronts). I always forget that they were hot and would burn my hands when I hand pulled them back into place.
Old Jul 2, 2011 | 07:14 PM
  #4053
iiiiiekoiiiii's Avatar
thanx.
lol my rears were collecting all the rubber off the tires behind the rear quarters when tires were new. Now not so much lol.
Old Jul 3, 2011 | 05:26 PM
  #4054
shawndon's Avatar
I have 20x8.5/30 and 20x10/38 wheels for my sedan and will purchase hankook V12 tires 235/30 and 255/30. I want to lower it to fill in gap and set the wheels flush. I also have the BC coils w/SPC and swapped out the 8/10 springs for the 12/10's. I don't think I'll need a spacer in the rear but I know I will at least need a 10mm up front. Am I on the right track? Just want to be sure before I start my install.
Old Jul 3, 2011 | 07:00 PM
  #4055
4DGS's Avatar
Depends how low you go, you have a really slight stretch in the back... the tire sizes in general are actually really weird.
The front will be totally fine with a 10mm and you could even do a 15mm and not worry about it. I'd throw a 5 or 10mm on the back though as well (unless you plan to put the camber 100% in spec)
Old Jul 3, 2011 | 07:22 PM
  #4056
shawndon's Avatar
Thanks. What company would you recommend I get the spacers from? I do plan on being low also. I don't DD it so I want to have any wheel gap. In regards to the tire sizes, should I re-think that?
Old Jul 3, 2011 | 10:42 PM
  #4057
b-dRizZy's Avatar
Your almost running same *** me lol
Front I'm running a 20x8.5 +25 tire Achilies 225/30/20 w/ 15mm Spacer
Back I'm running a 20x10. +25 tire Achilies 245/30/20 and going to at 5mm spacer
Suspension Megan Coils street Editions I'm prett low as is but going more loaww in week or so
Make sure feders are rolled Flat and you should be ok and tires you should get a little more stretch since it's not DD go all the way.
And good brands spacers, I would say Ichiba or project Kicks hear lot off them. Make sure you post up picks I would like to see this
Old Jul 3, 2011 | 10:49 PM
  #4058
Cal's Avatar
Cal
Has a cop ever pulled you over , and give you a hard time cause he doesnt know what kind of car you have?
Old Jul 3, 2011 | 10:51 PM
  #4059
CandlestickPark's Avatar
ill Sedan
Haha, no never been pulled over for that reason. Only pulled over once in my G and that was for going 82 in a 65 totally my fault.
Old Jul 3, 2011 | 10:57 PM
  #4060
Matzo Ball's Avatar
haha, reminds me when I was visiting one of our work sites. Security guard walks behind my car to get the make/model. Comes back, looks at me and say "Ok, what the hell is it." I lolz.
Old Jul 3, 2011 | 11:42 PM
  #4061
shawndon's Avatar
Thanks for the info. I'll post pics after it's all done. Still have to order spacers.
Old Jul 4, 2011 | 06:58 PM
  #4062
4DGS's Avatar
Don't order Ichiba.
There's a company on Ebay that makes them and the quality is a million times better. ichiba use to be decent but they have cut corners every possible way and just aren't worth it.
Old Jul 4, 2011 | 07:30 PM
  #4063
shawndon's Avatar
Don't order Ichiba.
I'll check it out. Anymore info on what company it is?
Old Jul 4, 2011 | 08:06 PM
  #4064
ill Sedan
Don't order Ichiba.
Blain you've had bad experiences with Ichiba V2s?
Old Jul 5, 2011 | 08:58 AM
  #4065
shawndon's Avatar
I'm about to pull the trigger on the Hankook V12 tires. But I just remembered seeing the chart posted in this thread on how tires sizes run. Does anyone know if the V12s run true, large, or small?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
